Logitech PTZ Pro 2 Video Conferencing Camera
Quicklinx: DFHJWS00 Mfr#: 960-001186
£450.92 ex VAT
£541.10 inc VAT
Logitech PTZ Pro 2 delivers premium optics and life-like video to create the experience of sitting together in the same room, even if you are a thousand miles away. Technical improvements accent the camera's brilliantly sharp image resolution, outstanding color reproduction, and exceptional optical accuracy. At half the price of comparable models, PTZ Pro 2 is clearly the smart choice.
Logitech PTZ Pro 2 - conference camera
Conference camera - pan / tilt / zoom
Camera Mount Type
Tripod mount
13.1 cm x 13 cm x 14.6 cm
580 g
Wired
Camera
Optical Zoom
10 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Video Modes
1080p
Focal Length Control
Motorized zoom
Focus Adjustment
Automatic
Panning Range (degree)
260
Tilting Range (degree)
130
USB
1 - USB cable - external - 3.05 m
Security lock slot (cable lock sold separately), LED indicator, Jabber compatible, WebEx compatible, Skype compatible
Conference camera
Camera Mount Type
Tripod mount
Wired
13.1 cm
13 cm
14.6 cm
580 g
Camera
Colour - pan / tilt / zoom
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Motorized zoom
Optical Zoom
10 x
Focus Adjustment
Automatic
Horizontal Field of View (degree)
90
Panning
Range (degree)
260
Tilting
Range (degree)
130
Computer Interface
USB
Remote control, wall/table mount
1 x USB cable - external - 3.05 m
Plug and Play
Power adapter - external
Apple MacOS X 10.10 or later, Microsoft Windows 7 / 8.1 / 10
