Logitech Pro X Wireless Lightspeed Gaming Headset
Quicklinx: H939WS00 Mfr#: 981-000907
Type: Headset
Hurry, only 1 left in stock!
£183.33 ex VAT
£219.99 inc VAT
Step up to the pro-grade communications and precision audio you need to win, all with the freedom and mobility of LIGHTSPEED wireless.
  • BLUE VO!CE ADVANCED MIC TECHNOLOGY
    BLUE VO!CE microphone technology gives you a choice of real-time voice filters. Reduce noise, add compression, and de-essing, and ensure that your voice sounds richer, cleaner, and more professional. Get customizable, studio-quality, in-game voice comms with BLUE VO!CE via G HUB Gaming Software. ADVANCED FEATURES LIKE BLUE VO!CE AND DTS HEADPHONE:X 2.0 SURROUND SOUND FUNCTION ONLY ON PC VIA LOGITECH G HUB GAMING SOFTWARE. BLUE VO!CE INCLUDES DTS AUDIO ENHANCEMENTS
  • SUPREME COMFORT AND DURABILITY
    Pro-grade, sleek and minimal design that's built to last with premium aluminum fork and steel-reinforced headband. Ultra-comfortable memory foam earpads and headband are wrapped in plush leatherette and provide passive noise isolation. Extra velour earpads are also included for a softer feel
  • NEXT-GEN SURROUND SOUND
    DTS Headphone:X 2.0 goes beyond 7.1 channels with enhanced bass rendering, audio clarity and proximity cues. A new level of distance awareness differentiates between near field and far field audio, so your enemies location is pinpointed more than ever. Advanced features like Blue VO!CE and DTS Headphone:X 2.0 surround sound function only on PC via Logitech G HUB Gaming Software. Blue VO!CE includes DTS audio enhancements
  • PRO-G 50 MM DRIVERS
    PRO-G features a unique hybrid mesh construction to deliver amazingly clear and precise sound imaging. Hear footsteps and environmental cues with breathtaking clarity, and get the competitive edge you need to win. Now, with 50 mm drivers, the next-gen PRO-G achieves even more accuracy across a wider frequency range, plus higher-fidelity bass response
  • PRO SERIES
    PRO X WIRELESS headset joins a complete setup of pro-grade gear developed in collaboration with the world's top esports pros. All Logitech G PRO gear features our most advanced technologies designed with a single purpose: to help you win
  • Play To Win
    Logitech G is a global leader in esports, supporting hundreds of pro players around the world. We collaborate directly with pros to understand their needs and partner with them to create the best, competition grade gaming gear
Logitech G Pro X - headset
Headset - LIGHTSPEED - wireless
Compatibility
Windows
Recommended Use
Computer
Headphones Form Factor
Full size
Wireless
Wireless Technology
LIGHTSPEED
Sound Output Mode
Stereo
Sound Effects
DTS Headphone:X 2.0
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 91.7 dB
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Technology
Electret condenser
Controls
Volume, on/off, microphone on/mute
Compatibility
Windows
9.4 cm
13.8 cm
19.5 cm
370 g
Headband Material
Aluminium, leatherette, memory foam, steel
Earpad Material
Leatherette, memory foam
Recommended Use
Computer
Max Operating Distance
15 m
Audio Output
Full size
Wireless
Wireless Technology
LIGHTSPEED
Sound Output Mode
Stereo
Sound Effects
DTS Headphone:X 2.0
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
91.7 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Pro-G drivers, Blue VO!CE Mic Technology
Microphone
Boom
Detachable headset microphone
Electret condenser
Frequency Response
100 - 10000 Hz
Audio Input Details
Cardioid (uni-directional) - 100 - 10000 Hz
Remote Control
Controls
Wireless receiver, velour ear pads, carrying bag, USB-C to USB-A charging cable
Cable Details
USB-C charge cable - detachable - 1.8 m
Headset battery rechargeable
Run Time (Up To)
20 hour(s)
Type: Headset
Brand: Logitech
