Step up to the pro-grade communications and precision audio you need to win, all with the freedom and mobility of LIGHTSPEED wireless.
BLUE VO!CE ADVANCED MIC TECHNOLOGY
BLUE VO!CE microphone technology gives you a choice of real-time voice filters. Reduce noise, add compression, and de-essing, and ensure that your voice sounds richer, cleaner, and more professional. Get customizable, studio-quality, in-game voice comms with BLUE VO!CE via G HUB Gaming Software. ADVANCED FEATURES LIKE BLUE VO!CE AND DTS HEADPHONE:X 2.0 SURROUND SOUND FUNCTION ONLY ON PC VIA LOGITECH G HUB GAMING SOFTWARE. BLUE VO!CE INCLUDES DTS AUDIO ENHANCEMENTS -
SUPREME COMFORT AND DURABILITY
Pro-grade, sleek and minimal design that's built to last with premium aluminum fork and steel-reinforced headband. Ultra-comfortable memory foam earpads and headband are wrapped in plush leatherette and provide passive noise isolation. Extra velour earpads are also included for a softer feel -
NEXT-GEN SURROUND SOUND
DTS Headphone:X 2.0 goes beyond 7.1 channels with enhanced bass rendering, audio clarity and proximity cues. A new level of distance awareness differentiates between near field and far field audio, so your enemies location is pinpointed more than ever. Advanced features like Blue VO!CE and DTS Headphone:X 2.0 surround sound function only on PC via Logitech G HUB Gaming Software. Blue VO!CE includes DTS audio enhancements -
PRO-G 50 MM DRIVERS
PRO-G features a unique hybrid mesh construction to deliver amazingly clear and precise sound imaging. Hear footsteps and environmental cues with breathtaking clarity, and get the competitive edge you need to win. Now, with 50 mm drivers, the next-gen PRO-G achieves even more accuracy across a wider frequency range, plus higher-fidelity bass response -
PRO SERIES
PRO X WIRELESS headset joins a complete setup of pro-grade gear developed in collaboration with the world's top esports pros. All Logitech G PRO gear features our most advanced technologies designed with a single purpose: to help you win -
Play To Win
Logitech G is a global leader in esports, supporting hundreds of pro players around the world. We collaborate directly with pros to understand their needs and partner with them to create the best, competition grade gaming gear
- Logitech G Pro X - headset
- Product Type
- Headset - LIGHTSPEED - wireless
- Compatibility
- Windows
- Recommended Use
- Computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- LIGHTSPEED
- Sound Output Mode
- Stereo
- Sound Effects
- DTS Headphone:X 2.0
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 91.7 dB
- Impedance
- 32 ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Controls
- Volume, on/off, microphone on/mute
- 2-year warranty
- Product Type
- Compatibility
- Windows
- 9.4 cm
- 13.8 cm
- 19.5 cm
- 370 g
- Headband Material
- Aluminium, leatherette, memory foam, steel
- Earpad Material
- Leatherette, memory foam
- Recommended Use
- Computer
- Max Operating Distance
- 15 m
Audio Output
- Full size
- Wireless
- LIGHTSPEED
- Sound Output Mode
- Stereo
- Sound Effects
- Noise Isolating
- 20 - 20000 Hz
- Sensitivity
- 91.7 dB
- Impedance
- 32 ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
- Pro-G drivers, Blue VO!CE Mic Technology
Microphone
- Boom
- Form Factor
- Detachable headset microphone
- 100 - 10000 Hz
- Audio Input Details
- Cardioid (uni-directional) - 100 - 10000 Hz
Remote Control
- Controls
- Included Accessories
- Wireless receiver, velour ear pads, carrying bag, USB-C to USB-A charging cable
- Cable Details
- USB-C charge cable - detachable - 1.8 m
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 20 hour(s)
- Limited warranty - 2 years
