POP Home Switch lets everyone in the home control smart lighting, music, and more with the push of a button. Program each switch with up to three custom commands to add creativity and convenience throughout your smart home.
POP THE LIGHTS
Whether it's movies, reading, or a party, POP makes it easy to match lighting with lifestyle. Use the Apple Home app to set up HomeKit-compatible smart lighting, or use the POP app with Philips Hue , Insteon , LIFX, or Lutron lights for brightness, warmth, and color-then enjoy simple push-button control -
POP ONE, POP MANY
Whether you have connected lights, blinds, locks, thermostats, or other smart home devices, POP makes it easy to control many devices as one. Use either a HomeKit scene or a POP app recipe to trigger multiple smart devices, like setting smart locks and night-lights before going to bed -
POP AND PLAY
Use POP to start music, movies, and more. Program POP with your favorite Sonos stations and playlists. Or, combine POP with a Logitech Harmony hub-based remote to start an Activity like 'Movie Night'- the TV, cable box, and stereo turn on and smart lights dim -
POP NEARLY ANYWHERE
Because each button is wireless and battery-powered, you can use POP just about anywhere. Mount one by the front door, keep one on your nightstand, or carry one from room to room. Use POP Add-On buttons to add simple smart home control wherever you like
- Logitech POP Home Switch Starter Pack - switch - Bluetooth, Wi-Fi - white (pack of 2)
- Product Type
- Switch
- Packaged Quantity
- 2 (specifications are for single item)
- Power Source
- Battery
- Connectivity
- Wireless - Bluetooth, Wi-Fi
- Supported Host Device OS
- iOS, Android
- White
- 1-year warranty
- 6 cm x 0.9 cm x 6 cm
- Packaged Quantity
- Product Type
- Switch
- Power Source
- Battery
- Connectivity Technology
- Android 4.4 (KitKat) or later, iOS 9 or later
- Included Accessories
- 2 mounting tapes, plug-in bridge
- White
- Warranty
- 1-year warranty
- 6 cm
- 0.9 cm
- 6 cm
- 37 g
