The Logitech Wireless Mouse M205 offers plug-and-play simplicity in a portable design. Just plug the receiver into a USB port to get started - there's no software to install. The M205 features a snap-on mini-receiver that attaches to the mouse to make packing up convenient; and a design that makes it easy to slip into a bag and take with you. Intelligent battery management delivers months of use and added convenience. The receiver turns off the mouse when attached, and an indicator light eliminates surprises. High-definition optical tracking (1000 dpi) enables responsive and smooth cursor control.
- Logitech M205 - mouse - RF - black
- Mouse
- Connectivity Technology
- Wireless - RF
- Black
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- Battery
- 1 x AA type
- OS Required
- Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Black
Input Device
- Wireless
- Interface
- RF
- Optical
- 1000 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AA type
- Installed Qty
- 1
- OS Required
- Limited warranty - 3 years
