Logitech Plug & Play M205 Wireless Mouse - USB Wireless Receiver
Wireless Mouse M205
Quicklinx: 62RKWS00 Mfr#: 910-001073
The Logitech Wireless Mouse M205 offers plug-and-play simplicity in a portable design. Just plug the receiver into a USB port to get started - there's no software to install. The M205 features a snap-on mini-receiver that attaches to the mouse to make packing up convenient; and a design that makes it easy to slip into a bag and take with you. Intelligent battery management delivers months of use and added convenience. The receiver turns off the mouse when attached, and an indicator light eliminates surprises. High-definition optical tracking (1000 dpi) enables responsive and smooth cursor control.
Logitech M205 - mouse - RF - black
Mouse
Wireless - RF
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel
1 x AA type
Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Input Device
Wireless
RF
Optical
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Installed Qty
1
Limited warranty - 3 years
