With your Logitech Performance Mouse MX, you've got the power to conquer almost any surface and any task without a second thought.
Logitech Darkfield Laser Tracking
You get accurate, precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. -
Hyper-fast scrolling
Fly through long documents and Web pages with a single spin. Or use click-to-click scrolling for the precision you need when navigating lists, slides, and images. -
Sculpted, right-handed shape
Designed to fit your hand and put it in a comfortable, natural position. -
Logitech advanced 2.4 GHz wireless
You get the reliability of a cord plus cordless convenience and freedom - fast data transmission and virtually no delays or dropouts. -
Logitech unifying receiver
The tiny receiver stays in your notebook. There's no need to unplug it when you move around, so your mouse is always connected when and where you feel like using it. Plus, you can easily add a compatible wireless keyboard or number pad, or even another mouse - without the hassle of multiple USB receivers. -
Flexible recharging system
Recharge your mouse using a flexible micro-USB system through your computer or a standard wall outlet - even while you're using it. You'll always have the power you need to get the job done. -
Four thumb buttons
Do more with your mouse using the four customizable thumb buttons. Jump between open windows and applications, move backward or forward through Web pages, and zoom in and out of pictures.
- Logitech Performance MX - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Orientation
- Right-handed
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Scrolling wheel, Logitech Darkfield Laser Tracking
- Battery
- AA type
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- 1 x USB - 4 pin USB Type A
- AA type
- Software Included
- Drivers & Utilities
- OS Required
