Logitech PC 960 Stereo Headset USB For Business
Quicklinx: 5982WS00 Mfr#: 981-000100
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
More than 50 on order, no confirmed delivery date
£20.20 ex VAT
£24.24 inc VAT
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband with volume controls and adjustable boom microphone . The noise-canceling microphone filters unwanted background noise. Ships in a business pack.
Stylish, adjustable over-the-head design for a comfortable fit that won't slip off. Ultra-soft earpad, flexible and lightweight design ensures all-day comfort. USB cable for simple, plug-and-play connectivity. Adjustable boom microphone for precise positioning; the microphone rotates out of the way when not in use. In-line volume or mute controls for easy and precise control. Microphone mute indicator light tells you when mute is enabled. Advanced digital USB delivers superior stereo sound quality. Noise-canceling microphone filters background noise for clearer conversations. White-box business packaging is easy to ship, store and recycle. 3-Year warranty.
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband for all day wear, with in-line controls for volume and mute adjustment. The boom microphone can be adjusted to the optimal position for clearer conversations. The noise-cancelling microphone filters backgound noise, and rotates out of the way when not in use. Ships in a business pack ideal for system builders, integrators and value-added resellers
  • HEAR EVERY WORD
    Whether listening to a conference call, participating in a webinar or enjoying your favorite playlist, you'll get reliably clear digital stereo sound quality every time
  • CALLERS ONLY HEAR YOU
    A noise-cancelling mic ensures background activity is kept to a minimum so your callers hear your every word. The adjustable boom can be conveniently repositioned for better voice capture and the left-side mic rotates out of the way when you're through making calls
  • EASY TO USE, JUST PLUG AND PLAY
    Ready to go from day one. Just plug the USB connector into your computer and start talking. Convenient in-line controls located on the cord make it easy to adjust volume up/down or mute, all without disrupting the call or your workflow
  • COMFORTABLE ALL DAY WEAR
    Stylish and lightweight, the over-the-head design ensures a non-slip fit even if you're moving around. The lightweight headband features swivel-mounted ultra-foam ear cushions for all-day audio comfort
Logitech PC Headset 960 USB - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Volume, microphone on/mute
3-year warranty
Headset - wired
Recommended Use
Computer
Packaging Type
OEM
Audio Output
On-ear
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
Microphone
Boom
Wired
Sensitivity
-44 dBV/Pascal
Frequency Response
100 - 16000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Cable Details
Headset cable - 2.4 m
Limited warranty - 3 years
Resources
The following resources are available for the Logitech PC 960 Stereo Headset USB For Business
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
Price Range Ex VAT: 0 - 50
