Logitech Optical Gaming Mouse G400 - Optical - 8 button(s) - wired - USB
Quicklinx: 7KBFWS00 Mfr#: 910-002279
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
Consistent response ratio
Physical mouse movements translate to the same amount of cursor movement irrespective of speed: <0.5% variance compared to 5+% for some other "gaming" sensors.
Sculpted comfort grip
You'll appreciate our legendary, battle-tested shape for a natural grip that will keep you in the game longer
In-game sensitivity switching
Shift from pixel-precise targeting (400 dpi) to lightning-fast maneuvers (up to 3600 dpi) without ever having to interrupt play.
3600 dpi optical engine
1 millisecond report rate
Your mouse communicates over USB at a blazing-fast 1000 reports per second--as fast as USB can go, and eight times faster than standard USB mice.
Polytetrafluoroethylene feet
These low-friction feet glide effortlessly across almost any surface and practically eliminate friction to provide smoother movement.
DPI shift
Immediately switch to a predefined DPI level with a single button press--great for sniping.
Eight programmable buttons
Control your game and your mouse's performance with no configuration needed. Or, you can download our Logitech Gaming software and make it work exactly the way you want it to.
Durable build
With buttons rated up to 10 million clicks and feet tested to 250 km, this durable mouse will play hard for a long time.
Advanced software
You can easily customize your mouse to every game you play with the optional Logitech Gaming Software.
  • Precisely right
    When an ordinary mouse just won't do - a 3600 dpi optical engine, 2X greater dpi than the MX518, gives you precision targeting and pinpoint accuracy.
  • Stay on target
  • Battle-tested
  • 3600 dpi optical engine
  • 1 millisecond report rate
  • Polytetrafluoroethylene feet
  • In-game sensitivity switching
    Shift from pixel-precise targeting to lightning-fast maneuvers without ever having to interrupt play.
  • DPI shift
    Immediately switch to a predefined DPI level with a single button press - great for sniping.
  • Eight programmable buttons
  • Durable build
Logitech Gaming Mouse G400 - mouse - USB
Mouse
Wired - USB
133 g
Movement Detection Technology
Optical
Buttons Qty
8
Movement Resolution
3600 dpi
Performance
1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
1 x USB cable - integrated
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
133 g
Input Device
Wired
USB
Optical
Buttons Qty
8
Movement Resolution
3600 dpi
Performance
1 x USB - 4 pin USB Type A
C-Tick, FCC
Limited warranty - 3 years
