Discover the simplicity of enhancing your network performance with the Logitech network coupler. This essential tool is designed to seamlessly integrate with your existing network cables, providing a reliable and stable connection that boosts your Internet and network performance. Its durable construction ensures it can withstand the rigors of daily use, making it a valuable addition to any networking setup. With its easy setup process, you can enjoy improved connectivity in no time. Whether for home or office use, the Logitech network coupler is an efficient solution for extending the reach and performance of your network.
                USE YOUR OWN CABLE AT YOUR DESIRED LENGTH. IT'S THAT EASYWhen deploying Rally Mic Pods and Mic Pod Hubs, you may find yourself needing a little more cable, or a lot more cable. Easily extend the connection by using the Rally Mic Pod CAT Coupler to connect to a standard CAT cable
- Logitech network coupler - 21.5 cm
- Network coupler
- Packaged Quantity
- 2 (specifications are for single item)
- Length
- 21.5 cm
- 2-year warranty
- Designed For
- Logitech Rally; Rally Bar, Bar Mini, Mic Pod, Mic Pod Hub, Plus
- Packaged Quantity
- Network Cable Type
- Network coupler
- Length
- 21.5 cm
- 2.2 cm
- 5.8 cm
- 1.5 cm
- 2-year warranty
- Designed For
- Logitech Rally , Logitech Rally Bar, Bar Mini, Mic Pod, Mic Pod Hub, Plus
