The whisper-quiet USB-powered fan improves airflow around your notebook - and doesn't blow through your battery power. Whatever your decor, the colors and shape of this cooling pad will look right at home. The rear air intake lets you use the cooling pad on your lap or desk - and still maintain a steady, unobstructed airflow.
Virtually silent airflow
The slotted surface allows the USB-powered fan to distribute air quietly and evenly under your notebook. -
Sleek look
It's an easy fit in any room with colors and a shape that feel at home almost anywhere. -
Rear air intake
You get steady, unobstructed airflow that keeps the heat off you - whether it's on your lap or desk. -
Enclosed, durable construction
The enclosed design protects the internal fan from dust and damage. -
Low power consumption
Designed for efficiency, this cooling pad has a minimal impact on your notebook's battery.
- Logitech Cooling Pad N120 - notebook fan
- Product Type
- Notebook fan
- 28.3 cm x 37.2 cm x 4.9 cm
- 0.7 kg
- USB powered
- 3-year warranty
- Product Type
- Notebook fan
- 28.3 cm
- 37.2 cm
- 4.9 cm
- 0.7 kg
- USB powered
- Limited warranty: - 3 years
- Sound Emission
- 27 dB
