Power through your tasks with a premium keyboard and mouse combo. The advanced keyboard is full-sized and comfortable, with smart backlighting and customizable keys. The MX mouse features a speed-adaptive scroll-wheel, a unique thumb wheel and, thanks to its Darkfield Laser sensor, it tracks anywhere, even on glass. Both devices connect via a single Logitech Unifying USB receiver, offering 10m range, Easy-Switch technology and a Bluetooth Wireless Technology connection means you can connect the mouse to a second or even a third computer.
Advanced Backlit Typing
Type comfortably day or night with large, concave, laser etched keys with auto-adjusting backlighting and the Logitech PerfectStroke scissor key system -
MX Mouse Experience
A sculpted precision instrument with smart speed-adaptive scroll wheel and unique thumb wheel. Connect the mouse to multiple computers with Easy-Switch technology -
Mouse Anywhere, even on glass
The Darkfield Laser sensor tracks flawlessly where standard mice fail. Work with precision on glass and glossy surfaces -
Rechargeable convenience
The keyboard and mouse hold battery for up to 10 days on a full charge. A Micro USB charging cable is supplied -
Personalized productivity
Unlock the full range of possibilities and customize to your needs with Logitech Options Software
- Logitech MX900 Performance - keyboard and mouse set - US/UK Input Device
- Keyboard and mouse set
- Interface
- Bluetooth 4.0
- Wireless Receiver
- USB Logitech Unifying receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- US/UK
- Hot Keys Function
- Programmable, Easy-Switch
- Numeric Keypad
- Pointing Device
- Mouse - wireless - laser
- 2-year warranty
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 48.7 cm x 19.5 cm x 2.7 cm / 750 g , Mouse: 8.57 cm x 12.6 cm x 4.84 cm / 145 g
- Wireless
- Hot Keys Function
- US/UK
- Palm Rest
- Numeric keypad
Pointing Device
- Mouse - wireless
- Movement Detection Technology
- Laser
- Movement Resolution
- 2000 dpi
- Included Accessories
- USB extension cable (1.5m), micro-USB charging cable (1.8 m)
- Rechargeable
- Technology
- Lithium polymer
- Limited warranty - 2 years
