Logitech MX Palm Rest - Graphite
Quicklinx: GMLYWS00 Mfr#: 956-000001
£13.84 ex VAT
£16.60 inc VAT
MX Palm Rest offers a sturdy support and smooth surface, which provide all-day comfort. It's the premium palm rest you can place and position however you like. It is designed for thin keyboards, it's the perfect fit for Logitech MX Keys or Logitech Craft.
  • MOVE. ADJUST. TYPE
  • LASTING SUPPORT
    Firm yet comfortable wrist support keeps your hands in a nice, relaxed position so you can type comfortably for hours
  • HIGH-QUALITY MATERIALS
    Soft yet supportive memory foam is comfortable and durable - plus, it's stain-resistant and easy to clean
  • SUPPORT YOUR WAY
    It's smooth and pleasant to the touch, but doesn't slip or slide on surfaces. It stays put no matter how - or where - you type
Logitech MX Palm Rest - keyboard wrist rest
Keyboard wrist rest
42 cm x 6.4 cm x 0.8 cm
180 g
Grey
Keyboard wrist rest
42 cm
6.4 cm
0.8 cm
180 g
Grey
Brand: Logitech
