Logitech MX Mechanical Illuminated Keyboard - Graphite
Quicklinx: GVKDWS00 Mfr#: 920-010756
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, PC, Apple iOS, Mac
More than 50 In Stock
£128.76 ex VAT
£154.51 inc VAT
Ultra-precise and stable switches offer deep and reassuring key travel – in a low-profile form factor. Your fingers glide effortlessly across the matte surface of the keys – and dual color keycaps make it easy to orient your fingers and stay in your flow.
  • FEEL IT. MASTER IT
    Meet MX Mechanical and MX Mechanical Mini – keyboards with extraordinary feel, precision, and performance
  • ULTRA FLUID MECHANICAL TYPING
    Low-profile mechanical switches deliver a next-level typing feel. Ultra-precise and stable switches offer deep and reassuring key travel – in a low-profile form factor. Your fingers glide effortlessly across the matte surface of the keys – and dual color keycaps make it easy to orient your fingers and stay in your flow
  • YOUR SET-UP. YOUR CHOICE
    Choose between the full-size MX Mechanical that features an integrated numpad or the space-saving minimalist MX Mechanical Mini. Both keyboards are crafted with an aluminum top case for ultimate stability and style
  • 3 UNIQUE SWITCH TYPES
    Choose the mechanical switch type that matches your style and preference of feel. MX Mechanical and MX Mechanical Mini are outfitted with one of three switches that each have a distinct feel and sound – Tactile Quiet, Clicky and Linear
  • FIND YOUR SWITCH
    Mechanical key switches with a satisfying tactile bump you feel – for precise feedback, reactive key reset, and less noise so your typing doesn't disturb those around you
  • SMART ILLUMINATION. NON-STOP PERFORMANCE
    The backlit keys magically light up the moment your hands approach, and automatically adjust to suit your lighting conditions – resulting in optimal battery consumption. Both keyboards also introduce a variety of immersive backlighting effects to draw you into your workflow. You can toggle between the effects in Logi Options+ or by simply pressing the Fn key and bulb key at the same time
  • MULTI DEVICE. MULTI OS
    Easily pair via Bluetooth Low Energy or the included Logi Bolt USB Receiver with up to three devices and switch between them at the push of a button
  • DO MORE WITH LOGI OPTIONS+
    Do more with your keyboards with Logi Options+. Work across devices and operating systems, change Fn key functions, check battery life, select backlighting effects, assign app-specific profiles and Smart Actions to optimize nearly every aspect of your workflow
  • CUSTOMIZE YOUR WAY
    Logi Options+ allows you to customize the entire F-row to any function you need. Easily switch the F-row priority between regular F-key functions, special functions, or personal app-specific customizations
  • FLOW BETWEEN DEVICES
    Installing Logi Options+ app enables Logitech Flow when paired with an MX mouse. Your MX keyboard follows your mouse through devices, allowing you to control multiple computers, in multiple operating systems, in one fluid workflow
  • CHARGE QUICKLY, CONNECT INSTANTLY
    MX Mechanical keyboards stay powered up to 15 days on a full charge – or up to 10 months with backlighting turned off
  • A CHOICE YOU'LL FEEL GOOD ABOUT
    Our goal? To design for sustainability. That means as we innovate our new generation of products, we reduce their carbon footprint in any way we can - from their overall construction to the tiniest component. All with zero compromises on quality and performance
Logitech Master Series MX Mechanical - keyboard - QWERTY - UK - graphite Input Device
Keyboard
Backlit
Bluetooth LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, mute, backlight control, Easy-Switch, on/off switch
Numeric Keypad
Key Switch Type
Tactile Quiet
Graphite
43.385 cm x 13.155 cm x 2.61 cm
828 g
Keyboard
Backlit
Bluetooth LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
Tactile Quiet
Adjustable Height
Numeric keypad
43.385 cm
13.155 cm
2.61 cm
828 g
Graphite
USB-C charging cable
Linux, Android, Google Chrome OS, Apple macOS 10.15 or later, Apple iOS 14 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later
Rechargeable
Lithium polymer
Run Time (Up To)
10 months
Type: Keyboard
Colour: Graphite
Compatibility: PC
Compatibility: Apple iOS
Compatibility: Mac
Brand: Logitech
