Logitech MX Master Wireless Mouse
HAND-SCULPTED COMFORT CONTOUR
Quicklinx: BMGPWS00 Mfr#: 910-004362
  • High-performance design
    Enjoy precision control and comfort thanks to the hand-sculpted design and well-positioned buttons and wheels
  • Darkfield Laser Tracking
    Turn the world into your mouse pad: works on virtually any surface with precise cursor control-even on glass and high-gloss surfaces. 4 mm minimum thickness
  • Smart speed-adaptive scroll wheel
    Navigate through long documents and web pages faster and easier with a precision scroll wheel that auto-shifts from click-to-click to hyper-fast scrolling
  • Unique thumb wheel
    Experience side-to-side scrolling with a stroke of your thumb. To unlock the full range of thumb wheel possibilities, install Logitech Options software
  • Customizable functions
    Unlock the full range of possibilities and customize the mouse to your needs with Logitech Options software
  • Dual connectivity
    Connect the wireless mouse quickly and easily with the included Logitech Unifying receiver or via Bluetooth Smart wireless technology
  • Easy-Switch technology
    Pair up to three devices (such as a desktop, laptop or a Windows tablet) and easily switch between them with the touch of a button
  • Rechargeable battery
    Fast-charge the battery with enough power for a full workday in just 4 minutes. The battery can last up to 40 days on a full charge. Battery life may vary based on user and computing conditions
  • Optimized productivity for Windows and Mac
    Enterprise ready and plug-and-play compatible with leading Microsoft operating systems and Mac OS X 10.8 or later
    Turn the world into your mouse pad: Works on virtually any surface with precise cursor control-even on glass and high-gloss surfaces. 4 mm minimum thickness
Logitech MX Master - mouse - Bluetooth, 2.4 GHz
Mouse
Wireless - Bluetooth, 2.4 GHz
8.57 cm x 12.6 cm x 4.84 cm
145 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 400 - 1600 dpi
Logitech Darkfield Laser Tracking, Logitech Unifying receiver, side wheel, Easy-Switch technology, gesture function, Smart Speed Adaptive Scroll Wheel, Bluetooth Smart (Windows 8, Windows 10 or later / Mac OS X 10.10 or later required)
Apple MacOS X 10.8 or later, Microsoft Windows 7, Windows 8, Windows 10 or later
Mouse
Wireless Receiver
8.57 cm
12.6 cm
4.84 cm
145 g
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
40 days
