Meet MX Master 3S – an iconic mouse remastered. Feel every moment of your workflow with even more precision, tactility, and performance, thanks to Quiet Clicks and an 8,000 DPI track-on-glass sensor.
AN ICON. REMASTERED
Meet MX Master 3S – an iconic mouse remastered. Feel every moment of your workflow with even more precision, tactility, and performance, thanks to Quiet Clicks and an 8,000 DPI track-on-glass sensor -
FEEL IT – BARELY HEAR IT
Introducing Quiet Clicks – create, make and do with the same click feel, but less noise. Quiet Clicks deliver satisfying, soft tactile feedback with 90% less click noise. Add that to a remarkably quiet MagSpeed electromagnetic scroll wheel for a high performance experience with zero distraction -
8K DPI ANY-SURFACE TRACKING
MX Master 3S is outfitted with our most accurate sensor ever, with next-gen precision and responsiveness. The 8,000 DPI optical sensor tracks virtually anywhere – even on glass -
SCROLL 1,000 LINES PER SECOND
MagSpeed Electromagnetic scrolling is precise enough to stop on a pixel and quick enough to scroll 1,000 lines per second. Oh, and it's nearly silent. The wheel's machined steel gives it a premium tactility and enough weight to offer a dynamic inertia you feel – but don't hear -
DO MORE WITH LOGI OPTIONS+
Work between devices and operating systems, customize individual buttons, set app-specific customizations, optimize nearly every action of your workflow, and set tracking speed in Logi Options+ -
APP-SPECIFIC CUSTOMIZATIONS
MX Master 3S is fully customizable in virtually every app you use. You'll work faster with predefined customizations optimized for your favorite apps such as Adobe Photoshop, Adobe Premiere Pro, Final Cut Pro, Google Chrome, Safari, Zoom, and Microsoft Teams, Word, Excel, PowerPoint, and Edge -
FLOW BETWEEN DEVICES
Logi Options+ lets you flow between computers by simply moving your cursor to the edge of the screen. Your MX keyboard follows your MX Master 3S and lets your workstream flow between Windows and macOS. Effortlessly transfer text, images, and files between computers – just copy on one and paste to the other -
CHARGE QUICKLY, CONNECT INSTANTLY
MX Master 3S stays powered for up to 70 days on a full charge – and gets three hours of use from a one-minute quick charge. Use the included USB-C charging cable to top up the power -
HAND SCULPTED, ALL DAY COMFORT
Work comfortably with an ergonomic silhouette crafted to support your palm and fingers. Textured surfaces provide a confident grip for total control. The unique tilt angle of MX Master 3S positions your arm in a more natural posture for better comfort. Optimally placed thumb controls are positioned for quick, intuitive access and fast navigation. The side scroll wheel follows the natural movement of the thumb for fluid and intuitive horizontal navigation
- Logitech Master Series MX MASTER 3S - mouse - Bluetooth, 2.4 GHz - pale grey
- Mouse - ergonomic
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- Pale grey
- 8.43 cm x 12.49 cm x 5.1 cm
- 141 g
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 7
- Movement Resolution
- 8000 dpi
- Performance
- Realtime sensitivity switching 200 - 8000 dpi
- Logitech Darkfield Laser Tracking, Easy-Switch technology, gesture function, rechargeable battery, thumb rest, MagSpeed wheel, customisable DPI, thumb wheel, Quiet Clicks technology
- OS Required
- Linux, Google Chrome OS, Android 8.0 (Oreo) or later, Apple macOS 10.15 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later
- Product Recycled Content
- 22 % - made of recycled post-consumer plastic
- 2-year warranty
- Mouse
- Wireless Receiver
- Ergonomic Design
- 8.43 cm
- 12.49 cm
- 5.1 cm
- 141 g
- Product Material
- Plastic, CNC machined steel
- Pale grey
Input Device
- Wireless
- Interface
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 7
- 8000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- USB-C charging cable
- Technology
- Lithium polymer
- Capacity
- 500 mAh
- Run Time (Up To)
- 70 days
- OS Required
- Limited warranty - 2 years
