Logitech MX Master 3S Performance Mouse - Graphite
Quicklinx: GVKBWS00 Mfr#: 910-006559
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: PC
31 In Stock
£87.44 ex VAT
£104.92 inc VAT
Meet MX Master 3S – an iconic mouse remastered. Feel every moment of your workflow with even more precision, tactility, and performance, thanks to Quiet Clicks and an 8,000 DPI track-on-glass sensor.
  • AN ICON. REMASTERED
  • FEEL IT – BARELY HEAR IT
    Introducing Quiet Clicks – create, make and do with the same click feel, but less noise. Quiet Clicks deliver satisfying, soft tactile feedback with 90% less click noise. Add that to a remarkably quiet MagSpeed electromagnetic scroll wheel for a high performance experience with zero distraction
  • 8K DPI ANY-SURFACE TRACKING
    MX Master 3S is outfitted with our most accurate sensor ever, with next-gen precision and responsiveness. The 8,000 DPI optical sensor tracks virtually anywhere – even on glass. You can adjust your tracking sensitivity in Logi Options+ and set the right level for your workflow and monitor resolution
  • SCROLL 1,000 LINES PER SECOND
    MagSpeed Electromagnetic scrolling is precise enough to stop on a pixel and quick enough to scroll 1,000 lines per second. Oh, and it's nearly silent. The wheel's machined steel gives it a premium tactility and enough weight to offer a dynamic inertia you feel – but don't hear. 90% FASTER 87% MORE PRECISE ULTRA QUIET
  • DO MORE WITH LOGI OPTIONS+
    Do more with your mice with Logi Options+. Work across devices and operating systems using Flow, customize individual buttons, set tracking speed, use predefined app-specific customizations and Smart Actions to optimize nearly every aspect of your workflow
  • APP-SPECIFIC CUSTOMIZATIONS
    MX Master 3S is fully customizable in virtually every app you use with Logi Options+. You'll work faster with predefined customizations optimized for your favorite apps such as Adobe Photoshop, Adobe Premiere Pro, Final Cut Pro, Google Chrome, Safari, Zoom, and Microsoft Teams, Word, Excel, PowerPoint, and Edge
  • FLOW BETWEEN DEVICES
    Logi Options+ lets you flow between computers by simply moving your cursor to the edge of the screen. Your MX keyboard follows your MX Master 3S and lets your workstream flow between Windows and macOS. Effortlessly transfer text, images, and files between computers – just copy on one and paste to the other
  • CHARGE QUICKLY, CONNECT INSTANTLY
    MX Master 3S stays powered for up to 70 days on a full charge – and gets three hours of use from a one-minute quick charge. Use the included USB-C charging cable to top up the power
  • HAND SCULPTED, ALL DAY COMFORT
    Work comfortably with an ergonomic silhouette crafted to support your palm and fingers. Textured surfaces provide a confident grip for total control. The unique tilt angle of MX Master 3S positions your arm in a more natural posture for better comfort. Optimally placed thumb controls are positioned for quick, intuitive access and fast navigation. The side scroll wheel follows the natural movement of the thumb for fluid and intuitive horizontal navigation
Logitech Master Series MX Master 3S - mouse - 2.4 GHz, Bluetooth - graphite
Mouse - ergonomic
Wireless - 2.4 GHz, Bluetooth
Graphite
8.43 cm x 12.49 cm x 5.1 cm
141 g
Wireless Receiver
Logitech Logi Bolt USB receiver
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
8000 dpi
Performance
Realtime sensitivity switching 200 - 8000 dpi
Thumb wheel, gesture function, rechargeable battery, Quiet Clicks technology, MagSpeed wheel, customisable DPI, Logitech Darkfield Laser Tracking, Easy-Switch technology, thumb rest
Android 8.0 (Oreo) or later, Apple iPadOS 14 or later, Apple macOS 10.15 or later, Google Chrome OS, Linux, Windows 10 / 11 or later
Product Recycled Content
27 % - made of recycled post-consumer plastic
Mouse
Wireless Receiver
Ergonomic Design
8.43 cm
12.49 cm
5.1 cm
141 g
Product Material
Plastic, CNC machined steel
Graphite
Input Device
Wireless
2.4 GHz, Bluetooth
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
7
Movement Resolution
8000 dpi
Performance
1 x USB - 4 pin USB Type A
Sustainability Information
Lithium polymer
500 mAh
Run Time (Up To)
70 days
Type: Mouse
Colour: Graphite
Compatibility: PC
Brand: Logitech
