Logitech MX MASTER 3 Mouse
Quicklinx: FW2XWS00 Mfr#: 910-005710
MX Master 3 is instant precision and infinite potential. It's an advanced Master series mouse - designed for creatives and engineered for coders. If you can think it, you can master it.
  • Crafted form meets intuitive control
    Work comfortably with a silhouette perfectly crafted for the shape of your palm. Create, make, and do more intuitively with ideally placed front/back, and gesture buttons - and a powerful thumb wheel.
  • Work faster with app-specific customizations
    Customize MX Master 3 and configure every action for your specific workflow. MX Master 3 is fully customizable in nearly every app you use - and you'll work faster with predefined customizations optimized for your favorite apps.
  • Work on multiple computers
    Seamlessly control multiple computers with your MX Master 3 by simply moving your cursor to the edge of the screen. Your MX Master 3 flows with you, even between operating systems.
Logitech MX Master 3 - mouse - 2.4 GHz, Bluetooth - black
Mouse
Wireless - 2.4 GHz, Bluetooth
8.43 cm x 12.49 cm x 5.1 cm
141 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 200 - 4000 dpi
MagSpeed wheel, Logitech Darkfield Laser Tracking, side wheel, gesture function
Microsoft Windows 7 / 8 / 10, Apple macOS 10.13 or later, Linux
Mouse
Wireless Receiver
8.43 cm
12.49 cm
5.1 cm
141 g
Input Device
Wireless
2.4 GHz, Bluetooth
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
USB-C charging cable
Lithium polymer
500 mAh
Run Time (Up To)
70 days
