MX Master 3 is instant precision and infinite potential. It's an advanced Master series mouse - designed for creatives and engineered for coders. If you can think it, you can master it.
MULTIPLE COMPUTERS, ONE MX MASTER 3
Seamlessly control multiple computers with your Flow-enabled MX Master 3 by simply moving your cursor to the edge of the screen. Your MX Master 3 flows with you, even between Windows and macOS operating systems. Effortlessly transfer text, images, and files between computers - just copy on one and paste to the other. 3 -
USB-C QUICK CHARGING
MX Master 3 stays powered for up to 70 days on a full charge - and gets three hours of use from a one-minute quick charge. 5 Use the included USB-C charging cable to top up the power -
TRACK FASTER – ON VIRTUALLY ANY SURFACE
MX Master 3 is faster and 5x more precise than the basic mouse 1 so you hit the right pixel every single time. Logitech Darkfield Tracking allows you to track on virtually any surface - even glass 4 - with best-in-class 4000 DPI precision -
CRAFTED FORM MEETS INTUITIVE CONTROL
Work comfortably with a silhouette perfectly crafted for the shape of your palm. Create, make, and do more intuitively with ideally-placed front/back, and gesture buttons – and a new thumb wheel
- Logitech MX Master 3 - mouse - Bluetooth, 2.4 GHz - graphite
- Mouse
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- Graphite
- 8.43 cm x 12.49 cm x 5.1 cm
- 141 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 7
- Movement Resolution
- 4000 dpi
- Performance
- Realtime sensitivity switching 200 - 4000 dpi
- MagSpeed wheel, gesture function, side wheel, Logitech Darkfield Laser Tracking
- OS Required
- Apple macOS 10.13 or later, Microsoft Windows 7 / 8 / 10, Linux
- 2-year warranty
- Mouse
- Wireless Receiver
- 8.43 cm
- 12.49 cm
- 5.1 cm
- 141 g
- Graphite
Input Device
- Wireless
- Interface
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 7
- 4000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- USB-C charging cable
- Technology
- Lithium polymer
- Capacity
- 500 mAh
- Run Time (Up To)
- 70 days
- OS Required
- Limited warranty - 2 years
