Experience a new level of flow state with MX Keys S.
High-performance keyboards, engineered for comfortable, fast, fluid typing, with smart illumination, and programmable keys.
MASTER YOUR FLOW
Experience a new level of flow state with MX Keys S - A high-performance keyboard, engineered for comfortable, fast, fluid typing, with smart illumination, and programmable keys. If you want to save space on your desk but not compromise on performance, you can choose the minimalist MX Keys Mini -
FAST FLUID PRECISE TYPING
Type with confidence and speed with spherically-dished keys shaped for your fingertips, minimizing the chances of a mistype, while increased key stability reduces noise -
SMART ILLUMINATION MADE SMARTER
Backlit keys light up when your hands approach the keyboard and automatically brighten or fade to suit your environment. Control on MX Keys S backlighting duration and brightness in Logi Options+ -
AUTOMATE REPETITIVE TASKS
Smart Actions on the Logi Options+ App allows you to skip repetitive actions by automating multiple tasks with a single keystroke -
ERGONOMIC DESIGN
The low-profile design & optimum angle for a natural wrist position, provides effortless precision and longer hours of typing comfort -
MULTI-DEVICE MULTI OS
Easily switch between up to 3 devices at the push of a button. Compatible with Windows, macOS, ChromeOS, Linux, iPadOS -
USB-C QUICK CHARGING
Stays powered for up to 10 days on a full charge or up to 5 months (backlighting turned off). Charge while you work with the included USB-C charging cable
- Logitech MX Keys S - keyboard - QWERTY - UK - graphite Input Device
- Keyboard - ergonomic
- Backlit
- Interface
- Bluetooth LE
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Easy-Switch, on/off switch, PerfectStroke
- Numeric Keypad
- Key Switch Type
- Scissor-Key
- Graphite
- 43.02 cm x 13.163 cm x 2.05 cm
- 810 g
- 2-year warranty
- Backlit
- Interface
- Bluetooth LE
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Wireless receiver: 1.84 cm x 1.44 cm x 0.66 cm / 2 g
- Wireless
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Membrane
- Key Switch Type
- Scissor-Key
- Numeric keypad
- USB-C (power only)
- Graphite
- Included Accessories
- USB-C charging cable
- FSC
- Key Life Span
- 10 million clicks
- OS Required
- Linux, Google Chrome OS, Android 8.0 (Oreo) or later, Apple macOS 10.15 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later
- Rechargeable
- Technology
- Lithium polymer
- Run Time (Up To)
- 10 days
- Limited warranty - 2 years
