Logitech MX Keys S Keyboard - Wireless - QWERTY - UK - Graphite
Quicklinx: HLFHWS00 Mfr#: 920-011584
35 In Stock
£94.05 ex VAT
£112.86 inc VAT
Experience a new level of flow state with MX Keys S.
High-performance keyboards, engineered for comfortable, fast, fluid typing, with smart illumination, and programmable keys.
  • MASTER YOUR FLOW
    Experience a new level of flow state with MX Keys S - A high-performance keyboard, engineered for comfortable, fast, fluid typing, with smart illumination, and programmable keys. If you want to save space on your desk but not compromise on performance, you can choose the minimalist MX Keys Mini
  • FAST FLUID PRECISE TYPING
    Type with confidence and speed with spherically-dished keys shaped for your fingertips, minimizing the chances of a mistype, while increased key stability reduces noise
  • SMART ILLUMINATION MADE SMARTER
    Backlit keys light up when your hands approach the keyboard and automatically brighten or fade to suit your environment. Control on MX Keys S backlighting duration and brightness in Logi Options+
  • AUTOMATE REPETITIVE TASKS
    Smart Actions on the Logi Options+ App allows you to skip repetitive actions by automating multiple tasks with a single keystroke
  • ERGONOMIC DESIGN
    The low-profile design & optimum angle for a natural wrist position, provides effortless precision and longer hours of typing comfort
  • MULTI-DEVICE MULTI OS
    Easily switch between up to 3 devices at the push of a button. Compatible with Windows, macOS, ChromeOS, Linux, iPadOS
  • USB-C QUICK CHARGING
    Stays powered for up to 10 days on a full charge or up to 5 months (backlighting turned off). Charge while you work with the included USB-C charging cable
Logitech MX Keys S - keyboard - QWERTY - UK - graphite Input Device
Keyboard - ergonomic
Backlit
Bluetooth LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch, on/off switch, PerfectStroke
Numeric Keypad
Key Switch Type
Scissor-Key
Graphite
43.02 cm x 13.163 cm x 2.05 cm
810 g
Backlit
Bluetooth LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Wireless receiver: 1.84 cm x 1.44 cm x 0.66 cm / 2 g
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Membrane
Key Switch Type
Scissor-Key
Numeric keypad
USB-C (power only)
Graphite
FSC
Key Life Span
10 million clicks
Linux, Google Chrome OS, Android 8.0 (Oreo) or later, Apple macOS 10.15 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later
Rechargeable
Lithium polymer
Run Time (Up To)
10 days
Brand: Logitech
