Logitech MX Keys S Combo - Keyboard and Mouse Set - Wireless - QWERTY - UK - Graphite
Quicklinx: HQ49WS00 Mfr#: 920-011613
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, Apple iOS, ChromeOS, Mac + 1 more
£128.99 ex VAT
£154.78 inc VAT
Discover the Logitech MX Keys S Combo, a keyboard and mouse set designed to enhance your productivity and streamline your workflow. With its wireless connectivity, compatible across a wide range of devices and operating systems, you can enjoy seamless transition between tasks. The keyboard features a backlit design with Scissor-Key technology, providing a comfortable and precise typing experience, complemented by a palm rest and numeric keypad. The Logitech MX Master 3S mouse, included in the set, offers exceptional control with its high-precision 8000 DPI optical sensor and customizable buttons. Committed to sustainability, the combo is FSC-compliant, ensuring the materials used are sourced responsibly. Powered by rechargeable lithium polymer batteries, the Logitech MX Keys S Combo delivers long-lasting performance, making it an ideal choice for professionals seeking efficiency and reliability.
  • A COMBO FOR SPEED AND PRECISION
    Power up your performance with MX Keys S and MX Master 3S. Comfort, stability, and precision combined in a pairing that helps you master your flow all day long
  • Key Features
    The keyboard has a stable, low-profile design and the mouse is crafted for your hand for better wrist posture. The included palm rest encourages a natural posture for all-day comfort
Logitech MX Keys S Combo - keyboard and mouse set - QWERTY - UK - graphite Input Device
Keyboard and mouse set
Backlit
Bluetooth LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch, on/off switch, PerfectStroke
Numeric Keypad
Pointing Device
Mouse - wireless - optical - right-handed
Buttons Qty
7
Key Switch Type
Scissor-Key
Graphite
Backlit
Bluetooth LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.02 cm x 13.163 cm x 2.05 cm / 810 g , Mouse: 8.43 cm x 12.49 cm x 5.1 cm / 141 g , Wireless receiver: 1.44 cm x 0.66 cm x 1.84 cm / 2 g
Wireless
Keyboard Name
Logitech MX Keys S
Hot Keys Function
QWERTY UK
Keyboard Technology
Membrane
Key Switch Type
Scissor-Key
Palm Rest
Numeric keypad
Pointing Device
Mouse - wireless
Pointing Device Name
Buttons Qty
7
Movement Detection Technology
Optical
Movement Resolution
8000 dpi
Batteries:
Lithium polymer
Orientation
Right-handed
USB-C (power only)
Graphite
USB-C charging cable, palm rest
FSC
Key Life Span
10 million clicks
Windows 10 / 11 or later, Apple macOS 10.15 or later, Linux, Google Chrome OS, Apple iPadOS 14 or later, Android 8.0 (Oreo) or later, Apple iOS 14 or later
Rechargeable
Lithium polymer
Run Time (Up To)
10 days
Colour: Graphite
Compatibility: Apple iOS
Compatibility: ChromeOS
Compatibility: Mac
Compatibility: PC
Brand: Logitech
