Logitech MX Keys Mini Keyboard - Graphite - UK
Quicklinx: HFSLWS00 Mfr#: 920-010495
Recommended Use: Office
Type: Keyboard
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Apple iOS, Mac, Android, PC
Hurry, only 1 left in stock!
£83.32 ex VAT
£99.98 inc VAT
Minimalist Wireless Illuminated Keyboard with emoji and dictation keys.
  • Master it with a mini
    Meet MX Keys Mini – a minimalist keyboard made for creators. The same MX high-performance engineered for comfortable, fast, fluid typing, with smart illumination, and programmable keys in a space-saving, form factor. The minimalist form factor of MX Keys Mini aligns your shoulders and results in better posture and improved ergonomics. Also available in a full-size version with an integrated numpad
  • Fast fluid precise typing
    Type with confidence and speed with spherically-dished keys shaped for your fingertips, minimizing the chances of a mistype, while increased key stability reduces noise
  • Introducing emoji, dictation and mic mute/unmute keys
    Smarter Fn Keys now give you the power to send emojis, mute and unmute your mic, and activate talk to text
  • Mini size, huge comfort
    The minimalist form factor aligns your shoulders and allows you to place your mouse closer to your keyboard for less hand reaching – for better posture and improved ergonomics
  • Smart illumination. Non-stop performance
    Backlit keys light up when your hands approach the keyboard and automatically brighten or fade to suit your environment. More backlighting customizations are available in Logi Options+
  • Do more with Logi Options+
    MX Keys Mini follows your Flow technology enabled MX Anywhere 3S or MX Master 3S so you can work across devices and operating systems in Logi Options+. The app also allows you to change Fn key functions, customize backlighting, assign app-specific profiles and Smart Actions shortcuts to optimize nearly every aspect of your workflow
  • USB-C quick charging
    MX Keys Mini stays powered up to 10 days on a full charge – or up to 5 months with backlighting turned off17Battery life may vary based on user and computing conditions. Charge while you work with the included USB-C charging cable
Logitech MX Keys Mini - keyboard - QWERTY - UK - graphite Input Device
Keyboard
Backlit
Bluetooth
Localization and Layout
QWERTY UK
Hot Keys Function
Mute, dictation, Emoji
Graphite
29.599 cm x 13.195 cm x 2.097 cm
506.4 g
Keyboard
Backlit
Bluetooth
Hot Keys Function
QWERTY UK
29.599 cm
13.195 cm
2.097 cm
506.4 g
Graphite
Linux, Google Chrome OS, Android 5.0 or later, Windows 10 or later, Apple macOS 10.15 or later, Apple iOS 13.4 or later, Apple iPadOS 14 or later
Rechargeable
Lithium polymer
Run Time (Up To)
5 months
Type: Keyboard
Colour: Graphite
Compatibility: Mac
Compatibility: Android
Compatibility: PC
Brand: Logitech
