Logitech MX Keys for Business - Keyboard - Backlit - Bluetooth, 2.4 GHz - QWERTY - Graphite
Quicklinx: H5SFWS00 Mfr#: 920-010250
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, PC, Mac, Apple iOS
40 In Stock
£79.61 ex VAT
£95.53 inc VAT
Buy MX Keys Business Keyboard. Features secured wireless, precision spherically dished keys, smart illumination, USB-C rechargeable, easy-switch, and more.
  • Metal-plate design
    The keyboard body is backed by a single metal plate and engineered for stability. It's a remarkably solid build that never slides around the desk. Increased key stability reduces noise while optimizing responsiveness. The balanced design with quality materials promotes comfort, inspiring confidence and focus at the desk.
  • Auto-adjust backlighting
    Features smart backlighting to increase productivity - regardless of lighting or the time of day. MX Keys for Business senses its surrounding ambient light automatically adjusting the keys' backlighting brightness. The backlighting turns on as hands approach it, then off when not in use.
  • With perfect-stroke keys
    Increased key stability reduces noise while optimizing responsiveness. Spherically-dished keys match fingertips' shape while the matte surface allows fingers to glide for efficient, comfortable work. Plus tactile reference for hand positioning makes it easy to orient fingers and stay in the flow.
  • Rechargeable power
    Works for up to 10 days on a full charge - or up to 5 months with backlighting turned off. Battery life may vary based on user and computing conditions. Users can work while it charges with zero downtime.
Logitech MX Keys for Business - keyboard - QWERTY - UK - graphite Input Device
Keyboard
Backlit
Bluetooth, 2.4 GHz
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch
Numeric Keypad
Graphite
43.02 cm x 13.163 cm x 2.05 cm
810 g
Keyboard
Backlit
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
Easy-Switch
QWERTY UK
Numeric keypad
43.02 cm
13.163 cm
2.05 cm
810 g
USB-C (power only)
Graphite
USB-C charging cable
FSC
MTBF
150,000 hours
Apple macOS 10.14 or later, Linux, Apple iOS 14 or later, Android 8.0 (Oreo) or later, Windows 10 or later, Google Chrome OS, Apple iPadOS 14 or later
Rechargeable
Lithium polymer
Shipping Width
14.75 cm
Shipping Depth
45.05 cm
Shipping Height
3.95 cm
Shipping Weight
1.04 kg
Colour: Graphite
Compatibility: PC
Compatibility: Mac
Compatibility: Apple iOS
Brand: Logitech
