Logitech MX Keys - Wireless Keyboard - Pan Nordic - Graphite
Quicklinx: GMLZWS00 Mfr#: 920-009411
£101.73 ex VAT
£122.07 inc VAT
Introducing MX Keys – the key to mastering your next big project. It's the first ever MX keyboard – designed for creatives and engineered for coders. If you can think it, you can master it.
  • MEET MX KEYS
  • FLUID, NATURAL, PRECISE – PERFECT STROKE KEYS
    Decades of Logitech expertise have gone into Perfect Stroke keys – ensuring that every keystroke is fluid, natural, and accurate. The spherically dished keys match the shape of your fingertips, and their round edges provide satisfying feedback - no matter where you strike the key. Matte coating has been applied to every key so your fingers glide effortlessly over the surface
  • TAKE COMFORT IN REMARKABLE STABILITY
    Confidently type on a keyboard crafted for support, stability, and precision. Increased key stability reduces noise and optimizes responsiveness so you feel – but don't hear – every keystroke. And the entire body of MX Keys is held together by a single metal plate – for a remarkably solid build that never slides around your desk
  • SMART ILLUMINATION. MADE SMARTER
    Proximity sensors detect your hands, illuminating the keyboard the moment your fingers approach. The backlit keys then fade off when you leave the desk - saving power for those moments of inspiration. Backlighting intensity automatically adapts to lighting conditions, or can be set manually
  • MULTIPLE COMPUTERS, ONE MX KEYS
    MX Keys follows your MX Master 3 – or other Flow-enabled mouse – from one computer to another, meaning you can type on multiple devices in one fluid workflow. Transfer files, documents, and images across computers and Mac and Windows operating systems. 1
  • USB-C RECHARGEABLE
    MX Keys stays powered up to 10 days on a full charge – or up to 5 months with backlighting turned off. 2  Use the USB-C charging cable to top up the power
  • MULTI OS
    MX Keys works with Windows, macOS , Linux , iOS and Android operating systems
  • EASY-SWITCH ENABLED
    Pair your keyboard with up to three devices and switch between them with the press of an Easy-Switch button. Use one MX Keys for your laptop, desktop or tablet
  • RESPONSIBLE PACKAGING
    All of the paper-based packaging for MX Keys is FSC -certified and made from a mix of materials from FSC-certified forests, recycled materials and other controlled sources. We used 97% less plastic resulting in a 64% reduction in the carbon footprint of the packaging,compared to the previous model
  • WORK BETTER. EVEN AT HOME
    Get the tools you need to stay focused and execute your highly specialized functions. It's the best desk solution for high achievers, with the right performance tools designed to take work to new heights
Logitech MX Keys - keyboard - Pan Nordic - graphite Input Device
Keyboard
Backlit
Bluetooth, 2.4 GHz
Wireless Receiver
USB Logitech Unifying receiver
Wireless
Localization and Layout
Pan Nordic
Numeric Keypad
Graphite
43.02 cm x 13.163 cm x 2.05 cm
810 g
Keyboard
Backlit
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Pan Nordic
Numeric keypad
43.02 cm
13.163 cm
2.05 cm
810 g
USB-C (power only)
Graphite
Linux, Microsoft Windows 7, Windows 8, Android 6.0 (Marshmallow) or later, Apple iOS 9 or later, Apple MacOS 10.11 or later
Rechargeable
Lithium polymer
Brand: Logitech
