Logitech MX Ergo S Wireless Trackball Mouse - Graphite
Quicklinx: J614WS00 Mfr#: 910-007260
33 In Stock
£89.15 ex VAT
£106.98 inc VAT
Shop MX Ergo S Mouse. Features advanced thumb control tracking, tilt angle, contoured design, customizable buttons, dual wireless connectivity, Options Plus, and more.
  • Efficient connectivity options
    The MX Ergo S supports Bluetooth and a Logitech Logi Bolt USB receiver, facilitating reliable wireless connections whether at home or on-the-go.
  • Programmable for flexibility
    With six programmable buttons and Easy-Switch technology, users can customize their experience and switch between devices with ease.
  • Advanced tracking performance
    Utilizing Logitech Advanced Optical Tracking, this trackball provides precision and accuracy across various surfaces, making it suitable for different tasks.
  • Designed for comfort
    The ergonomic structure promotes a natural hand position, while the rubber grip enhances overall user comfort during long periods of use.
  • Sustainable materials
    Made from recycled post-consumer plastic, the MX Ergo S promotes environmental responsibility without compromising on performance.
Logitech Ergo Series MX Ergo S - trackball - advanced - Bluetooth, 2.4 GHz - graphite
Trackball - ergonomic
Wireless - Bluetooth, 2.4 GHz
Graphite
9.98 cm x 13.25 cm x 5.14 cm
164 g
Wireless Receiver
Movement Detection Technology
Optical
Buttons Qty
8
Movement Resolution
2048 dpi
Performance
Realtime sensitivity switching 512 - 2048 dpi
20° tilt angle, Thumb Control, Quiet Clicks technology, 6 programmable buttons, fast charging, Easy-Switch technology, Bluetooth Low Energy Compatible, Logitech Advanced Optical Tracking, wireless encryption, Precision Mode, scrolling wheel
Product Recycled Content
20 % - made of recycled post-consumer plastic
Trackball
Wireless Receiver
Ergonomic Design
9.98 cm
13.25 cm
5.14 cm
164 g
Product Material
Rubber grip, plastic
Graphite
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
8
Movement Resolution
2048 dpi
Performance
1 x USB - 4 pin USB Type A
Sustainability Information
Lithium polymer
500 mAh
Run Time (Up To)
120 days
Software Included
Logi Options +
Shipping Width
11.12 cm
Shipping Depth
14.3 cm
Shipping Height
7.9 cm
Shipping Weight
368 g
Brand: Logitech
