Logitech MX Ergo S Wireless Trackball Mouse - Graphite
Quicklinx: J614WS00 Mfr#: 910-007260
Wired / Wireless: Wireless
Colour: Graphite
£89.15 ex VAT
£106.98 inc VAT
Shop MX Ergo S Mouse. Features advanced thumb control tracking, tilt angle, contoured design, customizable buttons, dual wireless connectivity, Options Plus, and more.
  • Elevated comfort and precision
    MX Ergo S, Logitech's most advanced wireless ergonomic trackball yet, with a 20-degree tilt angle and 6 customizable buttons - now with quiet clicks and quick USB-C charging (cable not included)
  • Maximize control. Minimize movement
    Track precisely and effortlessly with thumb control, while your hand stays fully supported on the sculpted ergonomic design with a soft rubber grip - a good fit for medium to large-sized hands. Switch between speed and high-precision tracking with a tap of the DPI button
  • Tilt for more comfort
    MX Ergo S is certified by ergonomists, with a unique 20-degree tilt angle that encourages a better forearm posture and reduces muscle strain in the forearm by 27% for elevated comfort throughout the day
  • Smoother days, your way
    Work faster with 6 customizable buttons and a DPI button to effortlessly switch cursor speed. Assign time-saving shortcuts, or Smart Actions tailored to your needs using the Logi Options+ App
  • Now with quick USB-C charging
    MX Ergo S is now compatible with USB-C charging (cable not included), with a full charge lasting up to 120 days and just a 1 minute charge for 24 hours of use. Compatible with any USB Type-C to USB Type-C or USB Type-A to USB Type-C cables, so you can use cable you already have in your home or at work
  • Now with quiet clicks
    Work without distraction with quiet clicks. Experience the same satisfying click feel on MX Ergo S but with 80% quieter clicks compared to MX Ergo
  • Built for advanced setups
    Connect up to 2 devices via Bluetooth or the included Logi Bolt receiver, and seamlessly switch between computers with the Easy-Switch button. MX Ergo S is compatible with Flow Technology, allowing you to work across devices and operating systems with the Logi Options+ App. Click and drag files across multi-OS devices
Logitech Ergo Series MX Ergo S - trackball - advanced - Bluetooth, 2.4 GHz - graphite
Trackball - ergonomic
Wireless - Bluetooth, 2.4 GHz
Graphite
9.98 cm x 13.25 cm x 5.14 cm
164 g
Wireless Receiver
Logitech Logi Bolt USB receiver
Movement Detection Technology
Optical
Buttons Qty
8
Movement Resolution
2048 dpi
Performance
Realtime sensitivity switching 512 - 2048 dpi
20° tilt angle, Thumb Control, Quiet Clicks technology, 6 programmable buttons, fast charging, Easy-Switch technology, Bluetooth Low Energy Compatible, Logitech Advanced Optical Tracking, wireless encryption, Precision Mode, scrolling wheel
Product Recycled Content
20 % - made of recycled post-consumer plastic
Trackball
Wireless Receiver
Ergonomic Design
9.98 cm
13.25 cm
5.14 cm
164 g
Product Material
Rubber grip, plastic
Graphite
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
8
Movement Resolution
2048 dpi
Performance
1 x USB - 4 pin USB Type A
Sustainability Information
Lithium polymer
500 mAh
Run Time (Up To)
120 days
Software Included
Logi Options +
Shipping Width
11.12 cm
Shipping Depth
14.3 cm
Shipping Height
7.9 cm
Shipping Weight
368 g
Colour: Graphite
Brand: Logitech
