Shop MX Ergo S Mouse. Features advanced thumb control tracking, tilt angle, contoured design, customizable buttons, dual wireless connectivity, Options Plus, and more.
Elevated comfort and precision
MX Ergo S, Logitech's most advanced wireless ergonomic trackball yet, with a 20-degree tilt angle and 6 customizable buttons - now with quiet clicks and quick USB-C charging (cable not included) -
Maximize control. Minimize movement
Track precisely and effortlessly with thumb control, while your hand stays fully supported on the sculpted ergonomic design with a soft rubber grip - a good fit for medium to large-sized hands. Switch between speed and high-precision tracking with a tap of the DPI button -
Tilt for more comfort
MX Ergo S is certified by ergonomists, with a unique 20-degree tilt angle that encourages a better forearm posture and reduces muscle strain in the forearm by 27% for elevated comfort throughout the day -
Smoother days, your way
Work faster with 6 customizable buttons and a DPI button to effortlessly switch cursor speed. Assign time-saving shortcuts, or Smart Actions tailored to your needs using the Logi Options+ App -
Now with quick USB-C charging
MX Ergo S is now compatible with USB-C charging (cable not included), with a full charge lasting up to 120 days and just a 1 minute charge for 24 hours of use. Compatible with any USB Type-C to USB Type-C or USB Type-A to USB Type-C cables, so you can use cable you already have in your home or at work -
Now with quiet clicks
Work without distraction with quiet clicks. Experience the same satisfying click feel on MX Ergo S but with 80% quieter clicks compared to MX Ergo -
Built for advanced setups
Connect up to 2 devices via Bluetooth or the included Logi Bolt receiver, and seamlessly switch between computers with the Easy-Switch button. MX Ergo S is compatible with Flow Technology, allowing you to work across devices and operating systems with the Logi Options+ App. Click and drag files across multi-OS devices
- Logitech Ergo Series MX Ergo S - trackball - advanced - Bluetooth, 2.4 GHz - graphite
- Trackball - ergonomic
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- Graphite
- 9.98 cm x 13.25 cm x 5.14 cm
- 164 g
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 8
- Movement Resolution
- 2048 dpi
- Performance
- Realtime sensitivity switching 512 - 2048 dpi
- 20° tilt angle, Thumb Control, Quiet Clicks technology, 6 programmable buttons, fast charging, Easy-Switch technology, Bluetooth Low Energy Compatible, Logitech Advanced Optical Tracking, wireless encryption, Precision Mode, scrolling wheel
- Product Recycled Content
- 20 % - made of recycled post-consumer plastic
- Trackball
- Wireless Receiver
- Ergonomic Design
- 9.98 cm
- 13.25 cm
- 5.14 cm
- 164 g
- Product Material
- Rubber grip, plastic
- Graphite
Input Device
- Wireless
- Interface
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 8
- 2048 dpi
- Performance
- 1 x USB - 4 pin USB Type A
Sustainability Information
- Technology
- Lithium polymer
- Capacity
- 500 mAh
- Run Time (Up To)
- 120 days
- Software Included
- Logi Options +
- Shipping Width
- 11.12 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 7.9 cm
- Shipping Weight
- 368 g
