Logitech MX Anywhere Laser Mouse - 2.4Ghz USB Wireless Receiver
Anywhere Mouse MX?
Quicklinx: 65T0WS00 Mfr#: 910-000873
You work everywhere. Now your mouse does, too. When you're using Logitech Anywhere Mouse MX with Logitech Darkfield Laser Tracking, you've got the power and precision to triumph over surfaces like glass tables where optical and standard laser mice fail.
A wireless mouse with a tiny, leave-in receiver and laser tracking that works wherever you do--even on glass
Darkfield Laser Tracking™
You get accurate, precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. Turn the world into your mouse pad.
Logitech® Unifying receiver
The tiny receiver stays in your notebook. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers
Compact, ergonomically designed
The compact, ergomomic design helps keep you comfortable wherever you want to use your laptop--at home, at work, or on the go.
Hyper-fast scrolling
You'll fly through documents and Web pages with a single spin. Click-to-click scrolling gives you the precision you need when navigating lists, slides, and images
Integrated thumb buttons
There's more control within your reach. Move quickly backward or forward through Web pages and within applications.
Logitech® Advanced 2.4 GHz wireless
You get the reliability of a cord with cordless convenience and freedom--fast data transmission and virtually no delays or dropouts.
  • Logitech Darkfield Laser Tracking
  • Hyper-fast scrolling
    Fly through long documents and Web pages with a single spin. Or use click-to-click scrolling for the precision you need when navigating lists, slides, and images.
  • Logitech advanced 2.4 GHz wireless
    You get the reliability of a cord plus cordless convenience and freedom - fast data transmission and virtually no delays or dropouts.
  • Logitech unifying receiver
    The tiny receiver stays in your notebook. There's no need to unplug it when you move around, so your mouse is always connected when and where you feel like using it. Plus, you can easily add a compatible wireless keyboard or number pad, or even another mouse - without the hassle of multiple USB receivers.
  • Comfortable even on the go
    Small enough to take with you, the sculpted shape fits your fingers for a naturally comfortable grip.
  • Back and forward thumb buttons
    There's more control within your reach. Move quickly through web pages.
Logitech Anywhere MX - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
2 x AA type
Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
Laser
1 x USB - 4 pin USB Type A
Carrying pouch
AA type
Installed Qty
2
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM, USB port
Limited warranty - 3 years
Resources
The following resources are available for the Logitech MX Anywhere Laser Mouse - 2.4Ghz USB Wireless Receiver
