Brand
Logitech MX Anywhere 3 Wireless Bluetooth Mouse
Quicklinx: GDR4WS00 Mfr#: 910-005988
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: PC
£72.38 ex VAT
£86.85 inc VAT
Master it, anywhere with MX Anywhere 3 is a compact performance mouse designed for mobile work, from the home office, to the cafe, to the airport lounge. The electromagnetic MagSpeed scroll wheel is faster, quieter, and more precise. A low-profile design is contoured for the shape of your hand. MX Anywhere 3 is built to withstand the bumps and drops of mobile work. And a track-anywhere sensor means you can work on virtually any surface.
  • THE SCROLL WHEEL, REINVENTED
    MagSpeed Electromagnetic scrolling is precise enough to stop on a pixel and fast enough to scroll 1,000 lines in a second. Oh, and it's nearly silent.  The wheel's machined steel gives it premium tactility and a dynamic inertia you feel-but don't hear
  • TRACK ANYWHERE - EVEN GLASS
    MX Anywhere 3 for Mac tracks on virtually any surface, including glass 4 mm minimum glass thickness . So you can work seamlessly at the desk, at a cafe, or even on the couch
  • USB-C TO USB-C CHARGING
    A USB-C to USB-C charging cable connects directly to your Mac without the need of a clunky dongle. MX Anywhere 3 for Mac stays powered for up to 70 days on a full charge – and gets three hours of use from a one-minute quick charge Battery life may vary based on user and computing conditions.
  • MODERN DESIGN, PREMIUM MATERIALS
    MX Anywhere 3 has been designed, developed, and engineered with Mac users in mind. Finished in an elegant Pale Gray finish, MX Anywhere 3 for Mac teams perfectly with your iMac, MacBook, and iPad
    MagSpeed Electromagnetic scrolling is precise enough to stop on a pixel and fast enough to scroll 1,000 lines in a second. Oh, and it's nearly silent.  The wheel's machined steel gives it premium tactility and a dynamic inertia you feel - but don't hear
  • TRACK ANYWHERE – EVEN GLASS
    MX Anywhere 3 tracks on virtually any surface, including glass 4 mm minimum glass thickness . So you can work seamlessly at the desk, at your favorite coffee shop, or even on the couch
  • GO-ANYWHERE COMFORT
    MX Anywhere 3 features a compact, low-profile design contoured for the shape of your hand – so you'll be comfortable for hours no matter where you work. Silicone side grips mean it's always soft to the touch. MX Anywhere 3 is built to withstand the bumps and drops of mobile work. It's designed to be thrown in your bag, and easily cleaned after months of use on the road
  • QUICK CHARGE WHILE YOU WORK
    MX Anywhere 3 stays powered for up to 70 days on a full charge – and gets three hours of use from a one-minute quick charge Battery life may vary based on user and computing conditions. . Top up the power with the included USB-C charging cable while using
  • ADOBE CREATIVE CLOUD WITH YOUR MX CREATIVE TOOLS
    Introducing a partnership empowering creators, makers and doers to explore their full capability. Learn how MX and Adobe can unlock true creative flow, and claim an Adobe Creative Cloud subscription – on us
  • Women Who Master
    The Logitech Master Series is dedicated to closing the gender gap in technology. Not only do we commit a portion of proceeds from every MX Master Series directly to Girls Who Code, but we also commit our support to organizations and projects that kickstart the right conversations across the industry
Logitech MX Anywhere 3 - mouse - Bluetooth, 2.4 GHz - graphite
Mouse
Wireless - Bluetooth, 2.4 GHz
Graphite
6.5 cm x 10 cm x 3.43 cm
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
6
Movement Resolution
4000 dpi
Programmable buttons, Logitech Darkfield Laser Tracking, silicone grips, MagSpeed wheel
Cable Length
1 m
Linux, Google Chrome OS, Windows 10 or later, Apple macOS 10.15 or later, Apple iPadOS 13.4 or later
Mouse
Wireless Receiver
6.5 cm
10 cm
3.43 cm
Graphite
Input Device
Wireless
Bluetooth, 2.4 GHz
Laser
Buttons Qty
6
Movement Resolution
4000 dpi
Cable Length
1 m
1 x USB-C - 24 pin USB-C
USB cable (Type-C to Type-A)
Run Time (Up To)
70 days
Shipping Width
5.74 cm
Shipping Depth
11.9 cm
Shipping Height
16.4 cm
Shipping Weight
233 g
Type: Mouse
Colour: Graphite
Compatibility: PC
Brand: Logitech
