Master it, anywhere with MX Anywhere 3 is a compact performance mouse designed for mobile work, from the home office, to the cafe, to the airport lounge. The electromagnetic MagSpeed scroll wheel is faster, quieter, and more precise. A low-profile design is contoured for the shape of your hand. MX Anywhere 3 is built to withstand the bumps and drops of mobile work. And a track-anywhere sensor means you can work on virtually any surface.
Speed scrolling
Speed, precision, and silence. Effortlessly scroll 1000 lines at once, and stop on a pixel. Auto-shift between ratchet and hyper-fast modes. -
Go-anywhwere comfort
Low-profile design contoured for your hand, with ultra-soft silicone side grips. Built to withstand the bumps and drops of mobile work. -
Track anywhere
Track on virtually any surface, including glass, meaning you can work seamlessly at the desk, at a café, even on the couch. -
Modern design
Modern design features a steel scroll wheel, grippy silicon side grips. -
Connect several devices
Connect up to three devices and switch between them at the tap of a button.
- Logitech MX Anywhere 3 - mouse - Bluetooth, 2.4 GHz - light grey
- Mouse
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- Light grey
- 6.5 cm x 10 cm x 3.43 cm
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 6
- Movement Resolution
- 4000 dpi
- Programmable buttons, Logitech Darkfield Laser Tracking, silicone grips, MagSpeed wheel
- OS Required
- Linux, Google Chrome OS, Windows 10 or later, Apple macOS 10.15 or later, Apple iPadOS 13.4 or later
- Mouse
- Wireless Receiver
- 6.5 cm
- 10 cm
- 3.43 cm
- Light grey
Input Device
- Wireless
- Interface
- Laser
- Buttons Qty
- 6
- 4000 dpi
- 1 x USB-C - 24 pin USB-C
- Included Accessories
- USB cable (Type-C to Type-A)
- Run Time (Up To)
- 70 days
- OS Required
- Shipping Width
- 5.74 cm
- Shipping Depth
- 11.9 cm
- Shipping Height
- 16.4 cm
- Shipping Weight
- 233 g
