Harness the power of Logitech Flow and seamlessly move content between three devices. Fly through documents with hyper-fast scrolling. Work comfortably for hours thanks to a compact, sculpted shape and long-lasting rechargeable battery.
EFFORTLESS MULTI-COMPUTER WORKFLOW
Gone are the days when working across several computers meant sending yourself cumbersome emails with attachments or tediously copying files on a flash drive. With Logitech Flow you can move your mouse cursor across three computer screens and even copy/paste text, images and files from one computer to the other -
DARKFIELD HIGH-PRECISION TRACKING
A premium mouse deserves the best quality tracking. That's why we designed the MX Anywhere 2S with a brand new, 4000 DPI precision sensor that can track everywhere – even on a sleek boardroom glass table -
RECHARGEABLE BATTERY
The quick-recharging battery means MX Anywhere 2S is ready when you are. Get enough power for a full day of work in only 3 minutes, with no downtime while recharging. A full charge can last up to 70 days. To recharge, just plug the mouse into your computer using the micro-USB charging cable and continue using it while it charges -
HYPER-FAST SCROLLING
Scroll through long documents or web pages faster and easier. Or, press the wheel and shift to click-to-click mode for precise navigation. In free-spinning mode, you coast smoothly and quickly through the longest documents and web pages, stopping instantly when you need to. In click-to-click mode, you can scroll precisely through spreadsheets or databases -
EASY-SWITCH AND DUAL CONNECTIVITY
Connect MX Anywhere 2S via the included Logitech Unifying Receiver or Bluetooth low energy technology. Thanks to Logitech Easy-Switch technology, pair up to 3 devices and easily switch between them with the touch of a button -
COMPACT, SCULPTED SHAPE
Compact enough to take anywhere, this wireless mobile mouse is designed to help you make things happen at work or on the go
 - Logitech MX Anywhere 2S - mouse - 2.4 GHz, Bluetooth - light grey
 - Mouse
- Connectivity Technology
 - Wireless - 2.4 GHz, Bluetooth
 - Light grey
 - 6.16 cm x 10.03 cm x 3.44 cm
 - 106 g
- Wireless Receiver
 - USB wireless receiver
- Movement Detection Technology
 - Laser
- Buttons Qty
 - 7
- Movement Resolution
 - 4000 dpi
- Performance
 - Realtime sensitivity switching 200 - 4000 dpi
 - Logitech Darkfield Laser Tracking, Logitech Unifying receiver, Easy-Switch technology, battery indicator, scrolling wheel, turbo scroll
- OS Required
 - Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.10 or later
 - 2-year warranty
 - Mouse
- Wireless Receiver
 - 6.16 cm
 - 10.03 cm
 - 3.44 cm
 - 106 g
 - Light grey
Input Device
 - Wireless
- Interface
- Max Operating Distance
 - Up to 10 m
 - Laser
- Buttons Qty
 - 7
 - 4000 dpi
- Performance
 - 1 x USB - 4 pin USB Type A
- Included Accessories
 - Micro-USB cable
- Technology
 - Lithium polymer
- Capacity
 - 500 mAh
- Run Time (Up To)
 - 70 days
- OS Required
 - Limited warranty - 2 years
