Logitech MX Anywhere 2 - Business Edition - Mouse - Right-Hand
Quicklinx: FPF8WS00 Mfr#: 910-005215
Darkfield laser tracking gives you flawless control on virtually any surface, including glass and high-gloss surfaces. This wireless travel mouse performs anywhere you need it to - glass tables in your hotel room, shiny laminate tops, train and airplane tray tables, and even your jeans. Unlike traditional laser and optical mice which use irregularities on the surface to track mouse movements, Darkfield technology uses the smallest possible detail to create a micro-road map of the surface.
  • Sculpted, portable design
    Designed to take anywhere and track anywhere, the MX Anywhere 2 offers the best combination of connectivity, size and comfort
  • Darkfield Laser Tracking
    Accurate, precise cursor control on virtually any surface-even on glass and high-gloss surfaces-where optical and standard laser mice fail
  • Customizable functions
    Unlock the full range of possibilities and customize the mouse to your needs with Logitech Options software
  • Hyper-fast or click-to-click scrolling
    Scroll through long documents or web pages faster and easier. Or, press the wheel and shift to click-to-click mode for precise navigation
  • Dual connectivity
    Connect the mouse quickly and easily with Bluetooth Smart wireless technology or the included Logitech Pico Unifying Receiver
  • Advanced 2.4 GHz wireless
    Experience the reliability of a cord with cordless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Easy-Switch technology
    Pair up to three devices, such as a desktop, laptop or Windows tablet, and easily switch between them with the touch of a button
  • Rechargeable battery
    One-minute charging provides two hours of usage, and a full charge lasts up to 2 months
  • Compatible with Windows and Mac
    Enterprise ready and plug-and-play compatible with leading Microsoft operating systems and Mac OS X 10.8 or later
Logitech MX Anywhere 2 - Business Edition - mouse - 2.4 GHz, Bluetooth - black
Mouse
Wireless - 2.4 GHz, Bluetooth
Orientation
Right-handed
6.16 cm x 10.03 cm x 3.44 cm
106 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 200 - 4000 dpi
Logitech Darkfield Laser Tracking, Logitech Unifying receiver, Easy-Switch technology, battery indicator, scrolling wheel
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.10 or later
Mouse
Wireless Receiver
Orientation
Right-handed
6.16 cm
10.03 cm
3.44 cm
106 g
Input Device
Wireless
2.4 GHz, Bluetooth
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
70 days
