Logitech Mouse M115 - Mouse - optical - 3 button(s) - wired - USB
Mouse M115
Quicklinx: 62VJWS00 Mfr#: 910-001268
Plug-and-play simplicity and a compact design make this optical mouse your perfect travel companion.
With easy setup, you just plug it into your USB port--it works right out of the box.
Compact design
The compact design makes it easy to slip the mouse into a bag and take it with you.
Optical tracking
You'll enjoy the smooth, accurate cursor control of optical tracking.
  • Plug-and-play
    Just plug the mouse into a USB port to get started - no software or batteries to install.
  • Compact, portable design
    Slip the mouse into a bag and take it with you wherever you go.
  • Optical tracking
    Optical sensor enables responsive and smooth cursor control.
Logitech M115 - mouse - USB
Mouse
Wired - USB
Western Europe
Movement Detection Technology
Optical
Buttons Qty
3
Scrolling wheel
1 x USB cable - integrated
Microsoft Windows XP, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista
Package Type
Retail
3-year warranty
Mouse
Western Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Package Type
Retail
Limited warranty - 3 years
