Plug-and-play simplicity and a compact design make this optical mouse your perfect travel companion.
With easy setup, you just plug it into your USB port--it works right out of the box.
Compact design
The compact design makes it easy to slip the mouse into a bag and take it with you.
Optical tracking
You'll enjoy the smooth, accurate cursor control of optical tracking.
Plug-and-play
Just plug the mouse into a USB port to get started - no software or batteries to install. -
Compact, portable design
Slip the mouse into a bag and take it with you wherever you go. -
Optical tracking
Optical sensor enables responsive and smooth cursor control.
- Logitech M115 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Localisation
- Western Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Scrolling wheel
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Microsoft Windows XP, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista
- Package Type
- Retail
- 3-year warranty
- Mouse
- Localisation
- Western Europe
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Cables Included
- Plug and Play
- Package Type
- Retail
- OS Required
- Limited warranty - 3 years
