Logitech MK950 Slim Combo for Business - Graphite
Quicklinx: HQ1GWS00 Mfr#: 920-012511
Recommended Use: Office, Leisure
Type: Keyboard and Mouse Set
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: ChromeOS, Mac, PC, Android + 1 more
21 In Stock
£71.54 ex VAT
£85.84 inc VAT
Redefine your office standards with Signature Slim Combo MK950 for Business. It combines the slim profile and typing experience that employees desire - with precise and super fast scrolling and multi-device switching for elevated productivity.
  • Wireless freedom
    Experience the freedom of wireless connectivity with Bluetooth 5.1 LE, allowing for a seamless and clutter-free workspace. The Logitech Signature Slim Combo MK950 for Business ensures a reliable connection up to 10 m away, providing flexibility and ease of use in any business environment.
  • Enhanced productivity
    Equipped with a numeric keypad and Easy-Switch technology, this keyboard and mouse set is designed to boost productivity. Switch effortlessly between devices, making multitask more efficient than ever.
  • Eco-friendly design
    Committed to sustainability, the Logitech Signature Slim Combo MK950 for Business incorporates post-consumer recycled plastic, aligning with eco-conscious business practices and reducing environmental impact.
Logitech Signature Slim Combo MK950 for Business - keyboard and mouse set - 100% full size - QWERTY - UK - graphite Input Device
Keyboard and mouse set
Bluetooth 5.1 LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch, screenshot
Numeric Keypad
Pointing Device
Mouse - wireless - right-handed
Buttons Qty
6
Performance
Realtime sensitivity switching 400 - 4000 dpi
Graphite
Bluetooth 5.1 LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.385 cm x 13.48 cm x 2.31 cm / 685 g , Mouse: 6.1 cm x 10.82 cm x 3.88 cm / 101.3 g , USB receiver: 1.87 cm x 0.61 cm x 1.44 cm / 1.7 g
Wireless
Keyboard Name
Logitech Signature K950 for Business
Hot Keys Function
QWERTY UK
Region
United Kingdom, Ireland
Keyboard Technology
Scissors
Adjustable Height
Numeric keypad
Pointing Device
Mouse - wireless
Pointing Device Name
Logitech Signature Plus M750 for Business
Buttons Qty
6
Thumb Buttons Qty
2
Movement Resolution
4000 dpi
Batteries:
1 Alkaline
Performance
Orientation
Right-handed
Supported Battery Type
AA x 1
Graphite
Works With Chromebook (WWCB) certified, FIPS, FSC, CarbonNeutral
MTBF
150,000 hours
Key Life Span
10 million clicks
Windows 10 / 11 or later, Apple macOS 11 or later, Google Chrome OS, Linux, Apple iPadOS 14 or later, Apple iOS 14 or later, Android 9.0 (Pie) or later
AAA type
Installed Qty
2
Required Qty
2
Alkaline
Run Time (Up To)
3 years
Shipping Width
45 cm
Shipping Depth
14.7 cm
Shipping Height
6.2 cm
Shipping Weight
1.115 kg
Sustainability Information
Product Recycled Content
62 % - post-consumer recycled plastic
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HQ1G 051325
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £56.25
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Recommended Use: Leisure
Colour: Graphite
Compatibility: Mac
Compatibility: PC
Compatibility: Android
Compatibility: Apple iOS
Brand: Logitech
Stock Status: Used Stock
