Logitech MK605 Notebook Kit - Riser, Keyboard & Mouse
Notebook Kit MK605
Quicklinx: 6KNQWS00 Mfr#: 939-000223
Improve your notebook comfort and connectivity.
The Logitech Alto Connect raises your notebook display for increased viewing comfort. You're more relaxed - and more productive. It's an attractive alternative to expensive monitors and docking stations.
Three High Speed USB ports make connecting peripherals a snap. An extra port on the front adds instant access to your personal digital devices - thumb drives, cameras, and MP3 music players.
The flexible, modular design means Logitech® Notebook Kit MK605 works with virtually any notebook (up to 15.6 inches). Use the right combination of mouse, stand and keyboard for your needs. You can be more comfortable and more productive, no matter what you're doing or where you're doing it.
Whether you prefer a mouse to a touchpad or just don't want to get up from the couch - the wireless laser mouse delivers smooth, responsive cursor control.
The pivoting notebook riser elevates your notebook to one of three angles. Pick the perfect position when you're watching movies in bed, sharing photos at the kitchen table or if you just want to sit up straighter at your desk.
For more involved tasks, you can place the compact, wireless keyboard where it feels best. You'll type more comfortably and efficiently thanks to the full-size layout and included number pad.
The tiny Logitech® Unifying receiver is small enough to stay in your notebook and connects both the included mouse and keyboard, so both are ready to use whenever you need them.
  • LOGITECH WIRELESS MOUSE M505 FEATURES:
    15-month battery lifeThe long battery life virtually eliminates the hassle of changing batteries. The on/off button saves power, while an indicator light eliminates surprises.
  • Laser precision
    Laser precision means you'll enjoy smoother tracking on just about any surface.
  • Logitech unifying receiver
    The tiny receiver stays in your notebook. Plus, you can easily add a compatible wireless mouse or keyboard - without the hassle of multiple USB receivers.
  • Logitech advanced 2.4 GHz wireless
    You get the reliability of a cord with cordless convenience and freedom - fast data transmission and virtually no delays or dropouts.
  • Ergonomic design
    The sculpted, ambidextrous design, with soft rubber grips, feels good in either hand - even after long hours of use. And it's portable for comfort on the go.
  • LOGITECH WIRELESS KEYBOARD K340 FEATURES:
    Space-saving designYou can type at your desk or take this keyboard with you - without compromising on comfort. The full-size layout and number pad combine to give you just the type of setup for a better typing experience.
  • Three-year keyboard battery life
    With a three-year keyboard battery life and USB rechargeable mouse, you won't have to deal with the hassle of changing batteries.
  • Advanced 2.4 GHz wireless
    So you can work or play in more places - like your comfy couch - the long-range wireless connection virtually eliminates delays, dropouts, and interference.
  • Low-profile keys
    You can shift your hands and wrists toward a more neutral position helping you type comfortably with keys that feel great and barely make a sound.
  • Programmable keys
    You're in charge with programmable F-keys. You can easily customize to open your favorite applications, folders, or web pages.
  • LOGITECH NOTEBOOK RISER N110 FEATURES:
    Ergonomic designThe riser elevates your notebook display so you'll sit taller, with your head up and eyes forward - a more natural, comfortable position.
  • Flexible setup
    You can use the stand with your favorite external keyboard and mouse and arrange each component to maximize your comfort and reduce fatigue.
  • Maximum adjustability
    Three tilt angles - 20, 30, or 40 degrees - and a rubber-soled swivel base let you select the position that works best for you.
  • Flips open and folds flat
    The folding design makes it easy to set up, take with you, and put away.
  • Versatile, sturdy design
    It works on just about any table or desk in your home or office - so you can be comfortable wherever you use your notebook.
