Logitech MK540 Advanced Wireless Keyboard and Mouse Set
Quicklinx: DPW9WS00 Mfr#: 920-008684
More than 50 In Stock
£43.84 ex VAT
£52.60 inc VAT
Meet MK540, a wireless keyboard and mouse combo built for precision, comfort, and reliability. The full-size keyboard features a familiar key shape, size, and feeling - optimized for precision and noise reduction. The palm rest and adjustable tilt legs keep you comfortable for long stretches and the contoured mouse is designed to fit perfectly into either palm.
  • PLUG AND PLAY WIRELESS COMBO
    Connect your keyboard and mouse with one tiny Logitech Unifying USB receiver. You'll get a reliable – and encrypted – wireless connection up to 10 meters away with virtually no delays or dropouts
  • FAMILIAR TYPING EXPERIENCE
    The keys have been optimized for improved accuracy and reduced noise – and your fingers will immediately feel at home on the familiar key surface and layout. The palm rest and adjustable tilt legs keep you comfortable for long stretches at the desk
  • CONTOURED COMFORT MOUSE
    The wireless mouse's contoured shape and soft rubber side grips are designed to fit comfortably in either your right or left palm – and enhanced tracking and precise cursor control keep you in command
  • PRODUCTIVITY AT YOUR FINGERTIPS
    Convenient and essential hot keys give you direct access to media, calculator and battery check functions. Preset Fn keys can even be personalized in Logitech Options to meet your specific needs
  • RELIABLE AND HASSLE-FREE
    Your keyboard won't require new batteries for 36 months and your mouse stays powered for 18 months. The keyboard is spill resistant to 60ml of liquid and abrasion resistant key printing ensures your keys won't quickly fade
Logitech MK540 Advanced - keyboard and mouse set - QWERTY - UK Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB Logitech Unifying receiver
Wireless
Localization and Layout
QWERTY UK
Numeric Keypad
Pointing Device
Mouse - wireless - optical - right and left-handed
Buttons Qty
3
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 45.73 cm x 19.35 cm x 2.4 cm / 805 g , Mouse: 6.18 cm x 11.15 cm x 3.92 cm / 73.5 g
Wireless
QWERTY UK
Palm Rest
Numeric keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Orientation
Right and left-handed
Supported Battery Type
AA x 1
Plug and Play
Google Chrome OS, Microsoft Windows 7 / 8 / 10
AA type
Installed Qty
2
Required Qty
2
