Your basket is empty
Logitech MK520 Wireless Combo Keyboard & Mouse
Quicklinx: 7461WS00 Mfr#: 920-002606
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Black/silver
Compatibility: PC
11 in stock
£36.42 ex VAT
£43.70 inc VAT
Express delivery Delivered on Tuesday
With a full-size keyboard featuring softly rounded keys; a hand-friendly, contoured laser mouse; and batteries that last, this sleek set puts convenience and control comfortably at your fingertips.
The keyboard's full-size layout gives you the room you need to type comfortably - with all the keys where you expect them to be. The concave design and softly rounded edges of the whisper-quiet, low-profile Logitech® Incurve keys™ position your fingers properly and invite your fingertips to glide from key to key, hour after hour. The palm rest gives your hands the perfect place to rest when you're not typing. And you can store your keyboard standing up to free up space on your desk when you're not using it.
The full-size mouse feels good in either hand - even after long hours of use - thanks to its hand-friendly, contoured design with soft rubber side grips. And laser precision means you'll enjoy smoother tracking on just about any surface so you can say goodbye to the frustrations of basic mice and tricky touchpads
Full-size layout
You've got the room you need to type comfortably--with all the keys where you expect them to be
Whisper-quiet , concave keys position your fingers properly, and their softly rounded edges invite your fingertips to glide from key to key, hour after hour
Hand-friendly laser mouse
Contoured sides and soft rubber grips keep your hand comfortable, supported, and in control. You'll enjoy smooth, precise tracking on virtually any surface
Batteries without hassle
A battery life of up to three years for the keyboard and one year for the mouse practically eliminates the need to replace batteries
Logitech® Unifying receiver
The tiny wireless receiver stays in your laptop--there's no need to unplug it when you move around--and connects both the keyboard and mouse
Advanced 2.4 GHz wireless
So you can work or play in more places--like your comfy couch--the long-range wireless connection virtually eliminates delays, dropouts, and interference
Instant media access
One-touch media controls on your keyboard let you mute your computer or skip to the next song instantly--without using your mouse.
Adjustable tilt legs
You can extend the folding legs to increase the keyboard tilt to 8 degrees to address your personal ergonomic needs.
Easy keyboard storage
You can store your keyboard standing up to free up space on your desk.
Type: Mouse
Compatibility: PC
Cherry MX Switch Colour: [N/A]
Brand: Logitech
Price Range Ex VAT: 0 - 50
