Logitech MK295 Silent Wireless Combo - White
Quicklinx: H95MWS00 Mfr#: 920-009823
Recommended Use: Leisure
Type: Mouse, Keyboard
Wired / Wireless: Wireless
Colour: Off white
Compatibility: PC
£33.33 ex VAT
£39.99 inc VAT
Stay focused on your work and cut out distractions. Meet Logitech MK295 Silent Wireless Combo featuring SilentTouch-an exclusive Logitech technology that eliminates over 90% of keyboard and mouse noise. It's the same clicking and typing feel of the world's bestselling combo without disruptive clicking and typing sounds.
  • LESS NOISE, MORE FOCUS
  • WORK WITH LESS DISTRACTIONS
    Our innovative SilentTouch technology removes over 90% of disruptive sounds for you and those around you-all while keeping the familiar typing and clicking feel of the world's bestselling combo
  • FULL-SIZE COMFORT
    The full-size keyboard provides all you need in the elegant and efficient design. 8 convenient shortcuts plus the full numpad simplify data entry and navigation
  • COMFORTABLE AND COMPACT MOUSE
    Contoured and portable shape. Smooth, precise clicking and pointing on most surfaces. Not to mention the impressive quietness made possible by SilentTouch
  • LAG-FREE WIRELESS
    Forget about drop-outs and lag thanks to a strong, reliable 2.4 GHz wireless connection with a 10 m range. Connect in just 3 seconds with one tiny receiver that can stay in your computer, freeing up desk space and keeping you on-track
  • DURABLE AND RELIABLE
    The spill-proof design, durable keys, and sturdy tilt legs with adjustable height add an extra layer of utility and comfort
  • LONG-LASTING BATTERY
    A 36-month keyboard and 18-month mouse battery life-along with on/off switches-means you can go for months without the hassle of changing batteries
  • A DESIGN CHOICE YOU'LL FEEL GOOD ABOUT
    MK295 is certified carbon neutral. This means the carbon impact of the product and packaging has been reduced to zero due to Logitech investment in carbon-offsetting and removal projects
Logitech MK295 Silent - keyboard and mouse set - QWERTY - English - off white Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
Nano USB Logitech Unifying receiver
Wireless
Localization and Layout
QWERTY English
Hot Keys Function
E-mail, volume, mute, play/pause
Protection
Spill-proof
Numeric Keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Off white
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 498 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 75.2 g , Wireless receiver: 1.44 cm x 1.87 cm x 0.61 cm / 1.8 g
Wireless
Hot Keys Function
QWERTY English
Adjustable Height
Protection
Spill-proof
Numeric keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Batteries:
1 Alkaline
Supported Battery Type
AA x 1
Off white
Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
AAA type
Installed Qty
2
Required Qty
2
Alkaline
Type: Mouse
Type: Keyboard
Colour: Off white
Compatibility: PC
Brand: Logitech
