You will enjoy the comfort and simplicity of a traditional full-size keyboard layout from day one. Enjoy the MK235's durable construction with sturdy tilt legs and spill-resistant design. There is anti-fading treatment on each key so you never worry about losing the letters from your keys. Simply plug the tiny USB receiver and enjoy a strong connection with no lag time.
Familiar keyboard layout
No learning curve involved. You will enjoy the comfort and simplicity of a traditional full-size keyboard layout from day one -
Long battery life
Type as long as three years between battery changes and use your mouse for up to a year before replacing the battery. The three year battery life prediction is based on approximately two million keystrokes per year in an office environment. Like all batteries, your experience may vary based on the use and computing conditions -
Built to last
Durable construction with sturdy tilt legs and spill-resistant design. Anti-fading treatment on each key so you never worry about losing the letters from your keys -
Reliable wireless
Simply plug the tiny USB receiver and enjoy a strong connection with no lag time. Your wireless keyboard and mouse will still be connected up to 10 meters (33 ft) away. While environmental conditions may cause the wireless range to vary slightly, you will always have the connection you need
- Logitech MK235 - keyboard and mouse set - US International Input Device
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- US International
- Protection
- Spill-resistant
- Numeric Keypad
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 3
- 2-year warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 43.55 cm x 13.75 cm x 2.05 cm / 475 g , Mouse: 6.15 cm x 9.77 cm x 3.52 cm / 70.5 g , Wireless receiver: 1.44 cm x 0.66 cm x 1.87 cm / 2 g
- Wireless
- US International
- Adjustable Height
- Protection
- Spill-resistant
- Numeric keypad
Pointing Device
- Mouse - wireless
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Included Accessories
- AA battery, 2 AAA batteries
- OS Required
- Linux Kernel 2.6 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
- AA type
- Installed Qty
- 2
- Limited warranty - 2 years
