When you need to adjust the volume, mute the microphone, or take manual control over camera position, this remote control uses radio frequency signals for reliable and discreet control from anywhere in the room.
Effortless control
Designed specifically for video conference cameras, this remote control allows for easy operation, making it simple to adjust settings or switch views during meetings. -
Broad compatibility
The remote is engineered to support a wide range of video conference cameras, ensuring seamless integration with existing equipment.
- Logitech remote control
- Remote control
- Supported Devices
- Video conference camera
- Designed For
- P/N: 960-001101, 960-001102
- Remote control
- Supported Devices
- Designed For
