The Logitech MeetUp 2 is an advanced video conferencing device designed to elevate your meeting experience. Equipped with a 6-microphone array and advanced audio output, it delivers crystal-clear sound, ensuring every participant is heard. The device's 4K digital video camera, featuring a wide field of view and digital zoom, captures every detail with precision, supported by AI noise reduction and Acoustic Echo Cancellation for excellent video quality.
Connectivity is seamless, thanks to a variety of interfaces including Bluetooth, HDMI, and USB-C 3.1, making it compatible with virtually any setup. Security is also a top priority, with AES encryption, a Kensington security lock slot, and advanced software features ensuring your communications are protected. With its intelligent design, including an integrated privacy shutter and cable management system, the Logitech MeetUp 2 is not only powerful but also a sleek addition to any conference room.
AI-driven experiences in small USB rooms
Meetup 2 brings intelligent audio and video experiences to USB-based deployments in small rooms. Watch your MeetUp 2 get more capable through regular updates that improve performance, add capabilities, and deepen integrations -
Simple to manage and deploy at scale
MeetUp 2 is easy to set up and manage in small spaces thanks to multiple mounting options, clean cabling, and remote management through Logitech Sync -
Single cable BYOD
Deliver elegant, single-cable BYOD connections with MeetUp 2 when it is paired with the optional Active USB Cable accessory
- Logitech MeetUp 2
- USB conference camera
- 46.92 cm x 7.3 cm x 7.33 cm
- 1.8 kg
- Video Input
- Digital video camera - SuperSpeed USB 3.0
- Audio Input
- 6-microphone array - omni-directional, beamforming
- Audio Output
- Speaker(s)
- Networking
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth LE
- Power
- AC 100-240 V
- System Requirements
- Microsoft Windows 10 or later, Apple MacOS
- 2-year warranty
- 46.92 cm
- 7.3 cm
- 7.33 cm
- 1.8 kg
- Dimensions & Weight Details
- Power adapter - Width 11.4 cm Depth 4.7 cm Height 3.23 cm
Video Input
- Digital video camera (colour) - desktop
- Interface Type
- Digital Video Capture Resolution
- 3840 x 2160
- Video Modes
- 4K
- Digital Zoom
- 4
- Camera Mechanical Design
- Pan / tilt / zoom
- RightSight 2 technology, RightSound 2 technology, -48° / +48° pan, -32° / +32° tilt, 113° field of view (horizontal), 80° field of view (vertical), 120° diagonal field of view, Acoustic Echo Cancellation (AEC), Voice Activity Detector (VAD), AI noise reduction, integrated privacy shutter
Audio Input
- 6-microphone array - integrated
- Microphone Operation Mode
- Omni-directional, beamforming
- Frequency Response
- 90 - 16000 Hz
Audio Output
- Speaker(s)
- Total Harmonic Distortion (THD)
- <2%
- Connectivity Technology
- Wired, wireless
- Data Link Protocol
- IPv4, IPv6
- Cable management, IP proxy, FQDN proxy, PAC file proxy, Public Key Infrastructure (PKI), ARM TrustZone, security slot (Kensington security lock compatible), AES encryption
- 1 x audio / video - HDMI input , 1 x audio / video - HDMI output , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C 3.1 - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - 3 m
- Mounting Kit
- Included
- AES-128, FSC
- Power Device
- Power adapter - external
- Voltage Required
- AC 100-240 V
- Software Included
- Logitech CollabOS
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
