Logitech Media Keyboard K200 - Keyboard - USB - English
Media Keyboard K200
Quicklinx: 7SWXWS00 Mfr#: 920-002733
The keyboard K200 for business is a sleek USB keyboard that puts your to-do tasks just one touch away. You can get more done in less time with eight hot keys that give you fast access to the things you do most. Your hands will enjoy the low-profile, virtually silent keys and full-size, standard layout with number pad. The slim keyboard isn't just sleek - it's tough with a spill-resistant design and sturdy, adjustable tilt legs.
  • Instant access to applications
    You can be more productive and help save energy with one-touch access to the Internet, e-mail, calculator and PC sleep.
  • Comfortable, quiet typing
    You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound to minimize distractions.
  • Full-size, standard layout
    The standard layout with a number pad and horizontal six-pack helps you be more productive and gives your hands space.
  • Easy-to-read keys
    The bold, bright white characters make the keys easier to read-perfect for those with less-than-perfect vision. They're less likely to wear off, too.
  • Spill-resistant design
    Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
  • Thin profile
    The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
  • Sturdy, adjustable tilt legs
    You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs. Rubber feet prevent slipping.
  • Plug-and-play USB connection
    Simple setup saves you time and resources-you just plug it into a USB port and start using it. Even the hot keys work right out of the box without software.
Logitech Media K200 - keyboard - English Input Device
Keyboard
USB
Wired
Localization and Layout
English
Hot Keys Function
Sleep, internet browsing, multimedia, calculator, e-mail, volume
Spillproof, tilt legs
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
USB
Hot Keys Function
English
1 x USB cable
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
