Logitech Master Series MX Mechanical Mini - Keyboard - QWERTY - UK - Graphite
Quicklinx: HKFLWS00 Mfr#: 920-010779
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, Apple iOS, Mac, PC
£103.81 ex VAT
£124.57 inc VAT
Low profile wireless mechanical keyboard in tactile, clicky or linear switches.
  • FEEL IT. MASTER IT
    The same mechanical feel and extraordinary precision and performance in a minimalist, space-saving, form factor. The minimalist form factor of MX Mechanical Mini aligns your shoulders and results in better posture and improved ergonomics. Also available in a full-size version with an integrated numpad. See MX Mechanical
  • ULTRA FLUID MECHANICAL TYPING
    Low-profile mechanical switches offer a deep and reassuring typing feel. Your fingers glide effortlessly across the matte surface of the keys – and dual color keycaps make it easy to orient your fingers and stay in your flow
  • 3 UNIQUE SWITCH TYPES
    MX Mechanical Mini is outfitted with one of three switches that each have a distinct feel and sound – Tactile Quiet, Clicky and Linear. Choose the mechanical switch type that matches your style and preference of feel
  • SMART ILLUMINATION. NON-STOP PERFORMANCE
    The backlit keys magically light up when your hands approach, and automatically adjust to suit your lighting conditions. You can also choose between a variety of immersive backlighting effects in Logi Options+
  • MULTI DEVICE. MULTI OS
    Easily switch between up to 3 devices at the push of a button. Compatible with Windows, macOS, ChromeOS, Linux, iPadOS
  • DO MORE WITH LOGI OPTIONS+
    Work across devices and operating systems, change Fn key functions, select backlighting effects, assign app-specific profiles and Smart Actions shortcuts to optimize nearly every aspect of your workflow
  • USB-C QUICK CHARGING
    MX Mechanical Mini stays powered up to 15 days on a full charge – or up to 10 months with backlighting turned off. Charge while you work with the included USB-C charging cable
Logitech Master Series MX Mechanical Mini - keyboard - QWERTY - UK - graphite Input Device
Keyboard
Backlit
Bluetooth LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch, on/off switch, backlight control, multimedia, mute
Key Switch Type
Tactile Quiet
Graphite
31.26 cm x 13.155 cm x 2.61 cm
612 g
Keyboard
Backlit
Bluetooth LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
Tactile Quiet
Adjustable Height
31.26 cm
13.155 cm
2.61 cm
612 g
Graphite
Android, Apple iOS 14 or later, Apple iPadOS 14 or later, Apple macOS 10.15 or later, Google Chrome OS, Linux, Windows 10 / 11 or later
Rechargeable
Lithium polymer
Run Time (Up To)
10 months
Colour: Graphite
Compatibility: Apple iOS
Compatibility: Mac
Compatibility: PC
Brand: Logitech
