Logitech Maser Series MX Keys Keyboard - Graphite
Quicklinx: FH6ZWS00 Mfr#: 920-009413
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, Mac, Apple iOS, PC
£90.72 ex VAT
£108.86 inc VAT
Introducing MX Keys – the key to mastering your next big project. It’s the first ever MX keyboard – designed for creatives and engineered for coders. If you can think it, you can master it.
  • MULTI OS
    MX Keys works with Windows, Mac, Linux 1 iOS and Android operating systems
  • EASY-SWITCH ENABLED
    Pair your keyboard with up to three devices and switch between them with the press of an Easy-Switch button. Use one MX Keys for your laptop, desktop or tablet
  • RESPONSIBLE PACKAGING
    All of the paper-based packaging for MX Keys is FSC -certified and made from a mix of materials from FSC-certified forests, recycled materials and other controlled sources. We used 97% less plastic resulting in a 64% reduction in the carbon footprint of the packaging,compared to the previous model
Logitech MX Keys Advanced Wireless Illuminated Keyboard - keyboard - QWERTY - UK Input Device
Keyboard
Backlit
Bluetooth, 2.4 GHz
Wireless Receiver
USB Logitech Unifying receiver
Localization and Layout
QWERTY UK
Hot Keys Function
Easy-Switch
Numeric Keypad
43.02 cm x 13.163 cm x 2.05 cm
810 g
Keyboard
Backlit
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Hot Keys Function
Easy-Switch
QWERTY UK
Numeric keypad
43.02 cm
13.163 cm
2.05 cm
810 g
USB-C (power only)
USB-C charging cable
Linux, Microsoft Windows 7, Windows 8, Android 6.0 (Marshmallow) or later, Apple iOS 9 or later, Apple MacOS 10.11 or later
Rechargeable
Lithium polymer
Type: Keyboard
Colour: Graphite
Compatibility: Mac
Compatibility: Apple iOS
Compatibility: PC
Brand: Logitech
