Logitech M90 Wired Scroll Mouse
Mouse M90
Customer rating: 5.0* (Write a review)
Quicklinx: 7FH3WS00 Mfr#: 910-001793
Recommended Use: Leisure, Office
Type: Mouse
Wired / Wireless: Wired
Colour: Dark grey
Compatibility: Mac, PC
£7.10 ex VAT
£8.52 inc VAT
With plug-and-play simplicity and high-definition optical tracking, you get a great value and reliable, comfortable control of your computer.
Simple to set up and use
Setup is fast and easy--just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away
Full-size comfort, ambidextrous design
Designed to keep either hand happy. So you'll feel comfortable, even after hours of use.
High-definition optical tracking
You'll enjoy responsive, smooth cursor control, precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi).
Built by Logitech
This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer.
  • Simple to set up and use
    Setup is fast and easy-just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away
  • Full-size comfort, ambidextrous design
  • High-definition optical tracking
  • Built by Logitech
  • Just the basics
    Setup is fast and easy. You can just plug the cable into a USB port and use it right away
  • No false moves
    You can't go wrong with precise optical tracking. It's a smooth mover-with or without a mouse pad
  • From the mouse experts
    You get the quality and design we've built into more than a billion mice
Logitech M90 - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
Western Europe
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel
Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
3-year warranty
Mouse
Orientation
Western Europe
Input Device
Wired
USB
Optical
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Additional Requirements
USB port
Limited warranty - 3 years
Customer reviews
Write a review for the Logitech M90 Wired Scroll Mouse here!
Reviewed by Maricel Gomez. Review Posted 04/07/2019
Item not available
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Recommended Use: Office
Type: Mouse
Colour: Dark grey
Compatibility: Mac
Compatibility: PC
Brand: Logitech
