Perfect mix of performance, precision, price with a micro-precise scroll wheel for the ultimate online navigation experience and ergonomic shape! The innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience. With its ergonomically shaped design and soft rubber grips, this mouse is built for comfort.
Micro-precise scroll wheel
With more grooves per millimeter, our new scroll wheel gives you the ultimate navigation experience. It makes scrolling through long web pages faster and easier -
Ergonomically shaped
The ergonomically shaped design and soft rubber grips conform to your hand to be naturally comfortable, and the compact size makes it easy to take with you wherever you use your computer-at home, at work, or anywhere else -
3-year battery life
With the world's longest-lasting battery, you can practically forget about changing batteries. Plus, the smart sleep mode saves power, while an indicator light eliminates surprises -
Connect with ease
You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it -
Logitech Advanced 2.4 GHz wireless
You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts -
Logitech Advanced Optical Technology
Laser-grade precision tracks over the most challenging surfaces-including smooth, glossy surfaces-that are problematic for standard optical mice. All while using less power so you get longer battery life and more convenience -
Page back/forward
To make surfing your favorite websites easier, you can move the tilt wheel left or right to move backward or forward while you're surfing the Web -
Scroll wheel for the control freak
Our innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience -
Built for hands like yours
With its ergonomically shaped design and soft rubber grips, this mouse is built for comfort -
Go for years
You'll get three years of battery life. It's so hassle free you might just forget it runs on batteries -
More power
You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver
- Logitech M525 - mouse - 2.4 GHz - blue
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Blue
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Scrolling wheel (4-way), battery indicator, Logitech Unifying receiver
- Battery
- 2 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Blue
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1 x USB - 4 pin USB Type A
- AA type
- Installed Qty
- 2
- Run Time (Up To)
- 3 years
- OS Required
- Limited warranty - 3 years
