Logitech M510 Wireless Mouse 2.4GHz USB Wireless Receiver - 5 Buttons
Wireless Mouse M510
Quicklinx: 7471WS00 Mfr#: 910-001825
A full-size, wireless laser mouse with more comfort and extra controls so you can do more, more easily.
A nice grip
With its contoured shape, soft rubber grips and handy controls, this full-size, wireless laser mouse M510 delivers the comfort and control you need to do more, more easily.
Two-year battery life
It practically eliminates battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises.
Side-to-side scrolling plus zoom
The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger.
Laser tracking
Laser precision means you'll enjoy smoother tracking on just about any surface.
Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.
Programmable controls
You can configure the controls to make them to do exactly what you want like switching applications, opening browser windows or jump to full screen while watching videos.
Back/Forward buttons
Moving quickly through documents or browsing your favorite Web sites is a breeze, especially for right-handers-- with buttons conveniently located under your thumb.
  • Comfortable shape and materials
    Enjoy a contoured shape with gently curved sides, broad palm area and soft rubber grips
  • Back/Forward buttons
    Moving quickly through documents or browsing your favorite websites is a breeze with buttons conveniently located under your thumb
  • Side-to-side scrolling plus zoom
    Scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger
  • Programmable controls
  • 2-year battery life
    With On/Off switch, smart sleep mode and battery life indicator, you might just forget this mouse runs on batteries
  • Connect with ease
    Plug the tiny Logitech Unifying receiver and leave it there. Plus, you can add up to six Unifying devices to it
  • Advanced precision
    Enjoy precise cursor control and responsive tracking on just about any surface
  • Extra controls right under your fingers
    You can do more, faster with Back/Forward buttons, side-to-side scrolling and zoom
  • Unifying technology - Plug it. Forget it. Add to it
    You can connect up to six Unifying devices to this tiny receiver
Logitech M510 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
5
Programmable buttons, zoom wheel, scrolling wheel, on/off power switch
2 x AA type
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
Right-handed
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
5
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
Run Time (Up To)
2 years
Additional Requirements
USB port
Limited warranty - 3 years
