Logitech M510 Mouse
Logitech M510 Mouse
Quicklinx: DN6HWS00 Mfr#: 910-001826
With its contoured shape, soft rubber grips and handy controls, this full-size, wireless laser mouse M510 delivers the comfort and control you need to do more, more easily.
  • Contoured design
    Designed to keep either hand happy. Soft side grips and a comfortable shape - so you'll feel good, even after long hours of use.
  • Back/forward buttons
    Moving quickly through documents or browsing your favorite web sites is a breeze, especially for right-handers - with buttons conveniently located under your thumb.
  • Side-to-side scrolling plus zoom
    The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger.
  • Programmable controls
    You can configure the controls to make them to do exactly what you want like switching applications, opening browser windows or jump to full screen while watching videos.
  • Logitech unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard - without the hassle of multiple USB receivers.
  • Laser tracking
    Laser precision means you'll enjoy smoother tracking on just about any surface.
Logitech M510 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
5
Programmable buttons, zoom wheel, scrolling wheel, on/off power switch
2 x AA type
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
Right-handed
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
5
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
Run Time (Up To)
2 years
Additional Requirements
USB port
Limited warranty - 3 years
